Gauges, how hard?
Old Apr 8, 2002 | 12:03 PM
Ryde _Or_Die's Avatar
Gauges, how hard?
Just wondering how hard it is to install gauges(boost, egt, water temp). Thanks alot.
Old Apr 8, 2002 | 12:19 PM
Josepi's Avatar
Despise Enmity
If you can wire a stereo, you can install em easy.
Old Apr 8, 2002 | 12:20 PM
Is that for electrical or for mechanical? Which is better? Thanks.
Old Apr 8, 2002 | 12:23 PM
Josepi's Avatar
Despise Enmity
Most all the temp gauges are going to be electrical, as far as the boost goes, the mechanical is going to be harder to put in because you have to run a vacuum line from the gauge to the engine bay. All up to what you want I guess. One thing i've wondered about is, if you have an FCD and use a elec boost gauge, will it go over 8.6 psi?
Old Apr 8, 2002 | 12:30 PM
I hope your not asking me, lol. I know nothing and am just trying to figure **** out about TIIs. Was stuck on the NAs for a few years.
Old Apr 8, 2002 | 01:37 PM
RETed's Avatar
Sure...
Your FCD is not hooked up to your aftermarket boost gauge...
-Ted
Old Apr 8, 2002 | 01:56 PM
rx7_turbo2's Avatar
Professor D.P
If the electrical gauge takes it's boost reading from the ECU then having an FCD might screw stuff up. If it takes it's reading from the boost sensor line before the FCD the gauge should be accurate.
Old Apr 8, 2002 | 02:28 PM
RETed's Avatar
An aftermarket electronic boost gauge has it's own dedicated pressure sensor.
-Ted
Old Apr 8, 2002 | 02:40 PM
rx7_turbo2's Avatar
Professor D.P
-Ted
Oh Ok. That makes sense.
Old Apr 11, 2002 | 01:25 PM
Ok, so do aftermarket gauges come with instructions or am I just supposed to know how to hook them up? Also, with an EGT gauge, where do I put the sensor and how do I get to it actually? Thanks alot.
Old Apr 11, 2002 | 03:18 PM
:bump:
Old Apr 11, 2002 | 04:48 PM
NZConvertible's Avatar
I'm a boost creep...
Yes they come with instructions, but most should be pretty self explanatory anyway. The thermocouple for an EGT gauge goes either in the exhaust manifold (requires removal for drilling and tapping) or the downpipe (again; remove, weld boss, drill, tap).
Donald Hampton
16
Nov 23, 2022 06:38 PM
rgordon1979
40
Mar 15, 2022 12:04 PM
wickedrx2
The Bad & Fugly Members
Jun 10, 2021 06:28 PM
