fog light schematic diagram
Old Aug 2, 2002 | 01:57 PM
Kahren's Avatar
i am not a girl
i was wonderign if someone has this scanned from teh shop manual. i needa 1994 schematic diagram for teh foglights on the touring model. i am trying to activate the foglights without havign to switch the lights or the parkign lights on.
Old Aug 2, 2002 | 03:30 PM
Touring FD3S's Avatar
Here is a diagram for you. I believe this is from a 93, but do not see a reason for this to be any different.
Here is a little write up as to how I did the exact thing you are looking to do(pasted from another thread):
Another option which I use and have used for quite some time now is rewiring them to turn on with the switch, whenever I want them on, which is always.
To do this, find the thick Red/yellow wire coming out of the switch. Cut this wire between the switch and the plug. Now, go to the store and buy a piece which will allow you to add a fuse to your fuse box through a fuse which is currently there. Don't know the technical term, but I bought mine at KMart in the auto fuse section, so you should be able to find them anywhere. There should be a wire coming out of this piece. Run a wire from this piece to the red/yellow wire coming out of the switch. As far as the fuse to "plug" into, I used the ABS fuse. NEVER had any problems with it, but I am not saying it is not dangerous, so pick a fuse carefully. I have had the foglight fuse blow (careless wiring on my part, fixed now) before without the abs fuse blowing, so this piece does work.
This supplies power to the foglight circuit, which only usually happens when the headlights are on. And the lights will go off when you turn off the ignition. The down side to this is that your foglights will not go off with your high beams, which as stated before, is illegal in most states. I'm sure that if you look further into the wiring, you can fix this, but I don't use my high beams too much, so it is not a concern for me. Any questions, feel free to ask.
Old Aug 2, 2002 | 03:57 PM
Kahren's Avatar
i am not a girl
ahhh yes....thanx that is exactly what i was lookign for
The1Sun
Sep 15, 2015 04:45 PM
RE-Mamamia
Sep 11, 2015 02:13 PM
The1Sun
Sep 7, 2015 10:21 PM
