Will This fmic work?
Old Oct 21, 2007 | 01:28 AM
Killert2's Avatar
Well i've been looking around for some nice intercoolers and found a brand new one with the deminsions of 27x6x2.75 with 2.5 inlets and outlets. I was wondering would this be a good enough size for a stock turbo and also for a t04?
Old Oct 21, 2007 | 02:03 AM
texFCturboII's Avatar
version 2.0
might be just a wee bit small IMO.
Old Oct 21, 2007 | 02:09 AM
pistones's Avatar
my FMIC is around that size, it depends what HP level you want to reach. i like small cores because i don't have to cut the body and i can keep the bumper support. that core is probably good up to 300 whp, maybe a tad more.
Old Oct 21, 2007 | 02:14 AM
FrankV702's Avatar
Yea. What are the overall goals for the car. I don't think that would be a bad IC at all.. Where are you seeing it at? Is it a bar and plate IC?
Boosted11's Avatar
Pistons are gay
Is there supposed to be a pic of the fmic?
Or is my computer just handicapped?
Old Oct 21, 2007 | 05:40 AM
wackaloo13's Avatar
if you are running normal t04z boost levels ie 15+psi, stick the biggest ic you can reasonably fit and run water or meth injection. i run a corksport 18x11x3 ic and i plan on running methanol injection on a aspec 500r turbo.
Old Oct 21, 2007 | 10:21 PM
Killert2's Avatar
Sorry i still haven't figured out how to post pics but heres the website so yall can check it out http://www.cxracing.com/mm5/merchant...ry_Code=IC25CO it should be the first one on the left it about 99 usd. My plans on hp for now since i'm on stock turbois whatever it'll make. I dont know what a bar and plate IC means so i can't answer that.
cristoDathird
28
May 30, 2019 08:47 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
Clacor
Aug 14, 2015 09:17 AM
