One supra Fuel Pump just wont do it!
Hey guys,
my Supra Nippendenso fuel pump was losing pressure a few weeks back dyno tuning with Steve Khan. I know the pump itself is going bad.
I want to run dual Supra In-tank pumps. One to primary rail and one to secondary rail. I just need the Nippendenso part # so Ic an order the stuff up!
I origanlly had pump installed at KDR but I cant get a hold of Dave for the part number.
Any help would be appreciated!
Thanks
ViperEater
Thanks
ViperEater
Trending Topics
i offer another easier solution to your fuel pump not being able to satisfy your engine's needs. it is premised on the condition that your pump is in good working condition. i run your pump and after analysis (thanks max) concluded it would be marginal for my application. instead of going to the bosch pump or twin pumps i installed a Kenne Bell Boost A Pump. ($200). at 3 psi boost the boost a pump flows an additional adjustable zero to 6 additional volts to my pump. bingo= all the fuel i need and no screwing around with my gas tank. the other advantage is that if you run more pump than you need you are recycling excessive gas from the tank to the engine and thereby heating it. hot gas contains less hp per volume. the unit is beautifully built and comes with everything you need. Kenne Bell has been making the unit for a long time and has a great website which contains lots of info. check it out.
howard coleman
howard coleman
ChrisRX8PR
Oct 18, 2015 04:01 PM
