How do i install door speakers and take door apart
I just just got new speakers for my rx and need some advice. I am just curious if anyone knows how the get the inside door panel off to install the new speakers. Any advice would be great. Thank You...
model? year?
Most of the time it is just removing all the screws, remove the door latch handle trim, then pop the plastic retaining clips, then slide the door panel up.
Yeah and be very careful taking the plastic clips off. You dont want to break those suckers. I think someone sells a special tool for removing them without breaking them. Not sure about that though.
1st take the screw out of the opening handle on the door; then pop off the mirror triangle; then the screw on the top right, bottom right, bottom left, bottom middle(usually hidden under the fuzzy carpet) and then the ones that hold the armrest handle on usually four of them; next go around panel and pop out the snaps that hold on the panel; finally slid panel up and voila--its off!! Next have a drink to celebrate!
DSM
youll need a special tool to release the latch on the window handle, if you dont have the tool you will need to get a screwdriver and try and find your way under it to puch the latch in so you can take it off so your door panel will come off to have access to your speaker
keegun
keegun
keegun
keegun
Trending Topics
What size are the speakers in the front of the doors? I think they are 6.5s right. I'm not sure if the door panels are different from year to year, but we are talking about the panel with the triangular shaped grill towards the front of the door right?
(just installed new speakers in my car an hour ago, PITA!!)
Originally posted by Deathbots
the ones under the dash? on my GXL they were 4" speakers.
It should not be a PITA.
Most of the speakers in the doors are 150mm which are true 6" speakers.
But note that many of the cheaper and asian brands tend to call a 6" speaker really a 6 1/2". MD quart, and JL are some of the few brands (that come to mind) that call a 6" a 6" and a 6 1/2 a 6 1/2".
True 6 1/2" however are the 170mm speakers.
4" to 5 1/4" change
hole is to small for 5 1/4 spks, unless you do some cutting and custom work. its easier to put 4"spks in.
i put 4" components in mine. The other way would be to put kick panel pods and put 6 1/2 comp's.
