My front brake rotors (track car)- pics
Old Dec 28, 2004 | 08:58 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
I have the borsche 'big reds' in the front in the track car. The old hats were some 'heavier' metal than aluminum so I had a set remade in aluminum and custom 'floating' rotors made so that I could move to floating/slotted rotors instead of the oem solid mounted crossdrilled oem porsche rotors.
I dont have somthing here that can weight things as minute as these new aluminum hats, but i can tell you that both of the news ones together dont weight as much as just one of the old hats.
and the rotors/hardware make it a true 'floating' system, the rotor can expand seperatly from the hat.
here are pics:
The hats/rotors were made by coleman racing and I got these done through a friend of mine that I met through track events, here is his contact info if you need somthing similar:
TJ Motorsports
tjmotorsports@ameritech.net
ask for Terry and tell him Damian sent ya :-)
Old Dec 28, 2004 | 10:41 PM
94RHDFD's Avatar
Formally 20b 3rd gen
Nice brakes
Old Dec 28, 2004 | 10:50 PM
BigIslandSevens's Avatar
Do you have a custom caliper mounting bracket or do the Big Reds bolt onto the factory spots? I am intrested in your brake set-up for my own. You have the stock rears correct? or the 99 spec? can't remember. I will go thru him if he can put the whole deal together. calipers and such or is there another secret person to go to for the big red calipers?
Old Dec 28, 2004 | 10:53 PM
Mr. Stock's Avatar
1993 RX7 R1
Damian,
Some history if you are interested:
The "Porsche" brakes on your car were originally purchased by me from Ultimate Garages. I eventually sold them to Steven Strickler because I decided to go with M2 AP Racing brakes instead. Steven Strickler eventually sold his car to Foko. And subsequently, he sold the car to you.
The rotor and hat combination weighed 21.5 lbs when I got them.
How much do the new rotor and hat combination weigh?
Old Dec 28, 2004 | 10:56 PM
Mr. Stock's Avatar
1993 RX7 R1
Originally Posted by BigIslandSevens
Do you have a custom caliper mounting bracket ?
The brake kit was made by Movit and sold initially through Ultimate Garages in New Jersey.
The brackets were, therefore, "custom" and weighed 1.5 lbs.
Old Dec 28, 2004 | 10:57 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
thanks :-) ill post more pics when i get them mounted
Old Dec 28, 2004 | 11:02 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
no, read above for the big red kit history info ....thanks mrstock :-)
my guy would only do hats/rotors setup for you
Old Dec 28, 2004 | 11:03 PM
Thanks Mr.Stock.& Damian. I'll check for a site and availability still.
Old Dec 28, 2004 | 11:10 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
u da man!!!
Old Dec 28, 2004 | 11:13 PM
Mr. Stock's Avatar
1993 RX7 R1
This is the website for Ultimate Garage.
The Big Brakes link is, however, dead.
Old Dec 28, 2004 | 11:17 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Damian,
thanks for the good info, on my scale the new rotor/hat/hardware come to: 18lbs... pretty good huh :-) a few lbs off each site :-) hahahh lol
Old Dec 28, 2004 | 11:20 PM
nextelbuddy's Avatar
my car i bought has big red porsche brakes up vront with cross drilled rotors.. only problem is the guy i bought the car from doesnt know what porsche the calipers are fro so i can get replacements and i also dont know what type of rotors to get when these wear out because he bought the car from someone else like this and that person can not be contacted
Old Dec 28, 2004 | 11:34 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
if its the 'big reds' then they are from a 993 turbo porsche, and you can email the contact i made int he first post to get non-oem rotors.
Old Dec 28, 2004 | 11:40 PM
Tim Benton's Avatar
FD title holder since 94
Damian,
Did these come in before the hatch?
Tim
Old Dec 28, 2004 | 11:47 PM
the_glass_man's Avatar
Will u do me a kindness?
Originally Posted by Tim Benton
Damian,
Tim
Old Dec 28, 2004 | 11:57 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Damian,
Tim
u bastid!!! and yes they did!!!!
Old Dec 29, 2004 | 12:01 AM
Tim Benton's Avatar
Jan 4th is the day
Tim
Old Dec 29, 2004 | 07:47 AM
Section8's Avatar
Excuse my ignorance, but what exactly is the benefit of having a floating rotor? Damian, you mentioned that it allows the rotor and hat to expand separately? Does this aid in head dissipation?
Old Dec 29, 2004 | 08:24 AM
alberto_mg's Avatar
do they make little bolts with safety wire for the point between the hat and rotor? doesn't look like there is a lot of thread on there...
Old Dec 29, 2004 | 08:39 AM
SurroundedBySe7ens's Avatar
Wow, nice brakes Damian. I've always been a fan of your track car, keep up the good work!
-Adam
Old Dec 29, 2004 | 09:02 AM
areXseven's Avatar
il Cosa Nostra e vivo!!
From: Dove le cose sono fatte il vecchio moda il senso
I just shorted-out my keyboard
Old Dec 29, 2004 | 09:34 AM
dubulup's Avatar
development
someone got some x-mas presents...
Old Dec 29, 2004 | 09:58 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
the hat and rotor are different metals so they expand at different rates when heated to the levels they get when braking as hard as track cars do. its 'nicer' on the rotor (and hat) if they are allowed to expand seperatly from each other rather than pulling/pushing on each other
Old Dec 29, 2004 | 10:01 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
i dont have them threaded all the way, there is plenty thread there once i have them fully seated, :-)
and the nuts and 'locking' style here the end of the nut is warped a bit.
Old Dec 29, 2004 | 10:07 AM
Mr. Stock's Avatar
1993 RX7 R1
Oops, forgot to post the link.
http://www.ultimategarage.com/
