MAKE IT STOP! (coolant buzzer)
Old May 29, 2003 | 01:45 PM
Black Magic's Avatar
2355lbs...
I did a search on this and i mainly saw everyone that blew their coolant seals and whatnot. I filled my car up all the way, no bubbles, everything is hooked up correctly and the damn thing still goes off.
---I will be installing an aftermarket temp gauge that has it own warning light. I check my coolant levels everytime before i start it up.
----since i do that all the time, i wont need the damn stock light/temp gauge.....
IS there any way to eliminate that buzzer? i pulled the little fuse box deal apart only to find a circuit board that has the little buzzer on it I read in one of the posts that someone knew how to ground it out, but never specified how to do it. Any help is greatly appreciated. thanks
-james
Old May 29, 2003 | 01:50 PM
TwinTriangles's Avatar
What's an RX-7 ?
Unplug the wire for the buzzer and ground it out on something, All it does is ground out when it touches the coolant, if you know its full get rid of the buzzer and make sure its always full...
Old May 29, 2003 | 01:51 PM
What's an RX-7 ?
Unplug the wire for the buzzer and ground it out on something, All it does is ground out when it touches the coolant, if you know its full get rid of the buzzer and make sure its always full... I had to do it on my FC becuz it kept goin off, but on the FC's its like ten times louder, There is one wire coming off the level sensor, cut it and ground it out anywhere...
Old May 29, 2003 | 01:53 PM
r0t0r-rooter's Avatar
call me Smokie Smokerson
Have you pressure-tested your coolant system?
Hopefully it's just a faulty buzzer, but it would suck if it wasn't.....
Old May 29, 2003 | 01:56 PM
What's an RX-7 ?
Word... My bet is its the buzzer, if you keep filling it up and your sure its not leaking from ANYWHERE, I mean not even from the overflow then the buzzer is smoking crack...
Old May 29, 2003 | 02:26 PM
2355lbs...
I heard on the FD's there are two sensors, the one on the filler neck which is the single black wire that connects to the sensor and runs right by the AC mount. The other is on the driverside by the front leading plug.Is this true? Would i have to ground them both out?
The car doesnt puff white smoke on start up or anything like that, it doesnt leak anywhere. When i top it off with coolant(making it overflow), the sensor by the filler neck sure as hell is getting water to it, i can visually see it damn near, and the buzzer/light stays on....When i get back home from work im goin to try and ground both those little bitches out. thanks for everyones advice so far.
Anyone else have some insight?
thanks
-james
Old May 29, 2003 | 02:42 PM
R-magic's Avatar
Check make sure the wire is not cut or split.....The only reason it could be going off is because there is no connection there.....Mine was like that!
Old May 29, 2003 | 02:50 PM
2355lbs...
IM going to try and ground out that SOB. i was just looking through the workshop manual and i guess it only has one coolant level sensor. (the one on the filler neck) Ill try grounding it out, if no luck, i found theplug on the driverside interior fuse box makes that damn thing stop. Unfortunatly it also cuts power to my oil press and water temp guages. Ill have an aftermarket water temp guage. THe stock oil pressure gauge is a joke as it is, so who cares about it. thanks
-james
Old May 29, 2003 | 03:25 PM
Mahjik's Avatar
Mr. Links
Test it, if it fails just replace it.
If the coolant level in the filler neck is above the sensor, then either the sensor is bad or the sensor wire is the problem.
Old May 29, 2003 | 03:34 PM
Kaotic Dan's Avatar
I've had this same problem since I bought my car. I replaced the whole damn wiring harness (for other reasons) and I also replaced the sensor. It still goes off constantly. I just dealt with it, now the new EMS doesn't pay attention to that sensor. Damn it was annoying.
streetlegal?
Mar 17, 2022 02:46 PM
Microtech
30
Apr 23, 2016 06:37 PM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
