what is the cheepest rebuild kit??
i was wondering who has the cheepest rebuild kit?? i saw the rebuild kit on mazdatrix and that was a hell of alot. besides why would it be so expensive to rebuild a rotory it has less parts in it im going to rebuilf my 93 jimmy and its gonna cost $140 for the whole kit and if i want new pistions it would be $350. when i rebuild an rx-7 i would like to put 3mm apex seals on it so does anyone know where you can get the a rebuild kit with3mm apex seals??
yeah you'll have to mill the rotors for 3mm, and that's about $150 a rotor. for just the gaskets try www.atkinsrotary.com it'll be about $1k for a good kit. good luck, and if you wanted cheap, get a tempo.
Originally posted by Rx-7Blazin
haha i still dont get why rebuild kits are so much its like nothing to rebuild a piston
Trending Topics
wow those are very inexpensive you we should let that sight get around mabe they will go cheeper if they have a mass amout of people going for them
http://www.rotaryaviation.com/overhaul_kits.htm
is that all you need and could you get buy with the basic kit or would you need a master kit???
i ordered from rotaryaviation, they've got the lowest prices around...i got the basic kit, so i reused my side seals, corner seals etc..also ordered an gasket kit and oil pump chain for 26US. They shipped via UPS.
i think i may get the O-ring kit for $153 and the 13b rotary installation gasket kit for $45.25 and buy the 3mm apex seals somewhere else. so where can i get some cheep 3mm apex seals?
also what type of material is the best when running it on a street ported dayly driver?
im pretty sure carbon seals are the soft seals that shatter into little soft non-abrasive pieces that dont damage your housings as much or at all compared to stock mazda seals. However i also belive they break much easier
eraumazda im going to go with 3mm because they hold up better under more stress. i like your responses huh?, mazda apex seals, why. crackheadme yea i think thats the diff really i think carbon seals seal better and dont wear the housing as much but break easer so dont last as long.
