FD Dash Speaker Size?
Originally posted by Palumbo1337
i suggest you dont buy one. to put it in is a bitch and once it breaks its a bitch. im not sure of the size, but i know there is a 4 somewhere in it
I easily removed my center speaker in less than a minute.....
HDP: It's funny because Crutchfield used to carry replacements for the center-channel speaker. It looks like Pioneer might have stopped making the replacement size...
Seriously, if your trying to get a good sound system, **** that speaker, and really u dont need the rears, get some good 400+ componants up fronts and set it up well and u will have a much better sounding system
its a center channel so it gets routed high mids and highs, 800hz~5000hz.
well, we all have enough mids, so i replaced mine with one really powerfull kicker tweeter, 150 rms-300 max. and the stereo sounds great. try that.
rajeev
rajeev
Trending Topics
Originally posted by edv
Sounds like a great time to install the nifty centre speaker gauge pod.....
why dont u get a better set of speakers for the rear and use the center channel speaker housing for your tweeters? i think panasonic radios work with a center channel speaker if you really want one. some radios now code for dolby but they are more expensive.
Originally posted by neofreak
bump
I want to use a center speaker.. not for the sound system though, so I still need to know what size to get. =)
bump
The speaker mount is 2-3/4" square. The diagonal mounting hole distance is 3-1/8". The actual driver is about 2-1/4" diameter. Hope that helps.
Ok everyone, I measured the damn thing....
Hi friends,
pls check here:
http://www.tobias-albert.de/ta_rx7/r.../dia_bose.html
or here:
http://www.tobias-albert.de/ta_rx7/r..._standard.html
greez
Tobias
pls check here:
or here:
greez
Tobias
Originally posted by HDP
I measured it when I first took it out. What I want to know is, who makes a replacement that size?
I searched around for a little while and couldn't find any of the big manfs making that speaker size anymore. Pioneer used to make a drop-in for that location but doesn't anymore.
Today I found the closest thing to an aftermarket replacement
http://www.simplyspeakers.com/14replacements.htm
near the bottom... full range 8 ohm Sony 2.75". Not sure how well it will work since the original is 4 ohms.
Don,
I thought you had an aftermarket headunit? Most of the head units don't use center speaker. The new high end headunits do.. but still not worth it since most of the musics are 2x2 and especially downloaded music. Only time I could see being useful would be surround sound for playing movies in your car or dvd music. But with the noise most FD's make and most people can't tell the difference between $200 system vs. $5000, its kind of pointless.
^ The center channel amp in the FD sums the speaker level outputs of the left and right channels together to get a mono signal. To make it continue to function in any aftermarket system all you have to do is connect the speaker wires of the left and right speakers back to the factory harness in the center console. The center channel amp will once again sum these signals and play them through the center speaker.
