carbing the FC
carbing the FC
DELLORTO 40 DHLA SIDE DRAFT CARB ....will that wor as a carb setup with the 13b side draft manifold made by atkins rotary........also what do i need to do to adapt my throttle linkages, fule, timing,.....ignition, etc..etc..
CB
PS~its a 88 SE
CB
PS~its a 88 SE
also check out the dellorto carb adapter on the Racing beat site its really sweet
www.racingbeat.com
its sooooo nice
www.racingbeat.com
its sooooo nice
40 is way to small 48 minimum 50 preferable.
Get a Cater fuel pump and bypass type regualator.
Clueless on the ignition, you could swap in an electronic distributor from a first gen.
Yes it will work
Ryan
Yes it will work
Ryan
Trending Topics
A 40DHLA is far too small if you want decent power out of a 13B. You'd be lucky to get more than stock.
You'll need a whole new ignition system using a distributor and twin coils out of an early carbed rotary (pre-84?).
Why are you doing this?
because
i ave a 88 SE with the following mods but i want the most power i can outa my NA, my safc wont work right, i need to try a few things, and also i am gonna get a street ported engine, io want a 13 second car to low 13's on a street port, with carb setup.......someone tell me what exactly i will need to do........please
also is what i haev gonna be anywhere near where i could be with a street port/carb setup?
CB
CB
not to start up a carb vs FI war! but carb is the way to go on the naturally aspirated... no matter what u do to fuel injection.... it wont give u the power the carb gives u... i dont know about getting bigger secondaries... if i hear the stock injectors on n/a's are good for lots of HP..
when i do my rebuild im goin mild street port wit a holley 650 racing beat 6 pt intake and make some decent power... as for 1/4 mile times you're lookin at maybe low to mid 14's.. you could probably run 13's but im not gonna promise anything my friend just sold a bridge ported 86 wit the carb setup exhaust header and he was runnin 13's constant.. but then again thats bridge port.. big difference...
but if u do go with carb.. u need the carb the intake manifold.. either a jay-tech or racing beat .. a 1st gen distributor.. and block off plates for the acv and the egr i believe..
You tell them Aaron. I agree with you. If carbs are so awesome then why aren't they using them in F1, Cart, IRL, FIA WRC, BTCC, etc.....? Just a thought. In SCCA soloII prepared classes there is a 10% weight penalty in my class for using non stock fuel injection on a car. Minimum weight is 1900# so that 10% added back would make my minimum weight be 2090#. Thats an increase of 190# because of fuel injection that according to many is not as good as a carb. Do they do this because carbs are better? I don't think so.
well i ran 14.9 with my mods in ym sig so get yourself a spoon and EAT MY ***......jk not to be rude but with a carb setup and exhaust and street port with my 50 shot of nos you would haev to be a retard of paralyzed not to get into the 13's.......honestly where is the grass you are smoking i want it!!!
Well that's the first time you've mentioned nitrous, so perhaps you should be grabbing the spoon...
Not being rude here, but from the questions you're asking, you seem a little shy on carb knowledge. You'll be lucky to see mid-15's with a 40DHLA, maybe 14's on the gas.
