What poly bushings should i get
Old Nov 6, 2002 | 06:46 PM
ioTus's Avatar
'84 5-letter
I'm replacing my suspension.
What bushigns should i order. ALready have front swaybar+ bushings, so what else.
Old Nov 6, 2002 | 08:01 PM
inittab's Avatar
I read your email
front: tension rod bushings
front: control arm bushings
rear: end links and bushings
rear: sway bar bushings
rear: lower control arm bushings
Do not replace the upper control arm bushings. It binds up the suspension too much. Victoria British sells a kit to do both the upper and lower control arm bushings but only do the lower. If you buy the kit I'll split the cost with you and buy the other half of the kit from you. Let me know....
Old Nov 6, 2002 | 08:18 PM
851stgen12a's Avatar
Off riding sportbikes!
For $150 Quickor Suspension in Portland they will do a complete bushing set. good quality to.
82transam's Avatar
Never Follow
stupid double post. my bad
82transam's Avatar
Never Follow
inittab: i thought you already had a full set of poly bushings on your car
Old Nov 6, 2002 | 09:42 PM
Directfreak's Avatar
I am a Jeeper Now.
Re: What poly bushings should i get
Another thread (by you)
One of my threads..
Do a Search with "suspension", and all your Q's will be answered.
Old Nov 7, 2002 | 08:28 PM
ioTus's Avatar
'84 5-letter
How about... no.
See my question was already answered!
Searching doesnt always bring up the right responses.
I love those dancing cartoon characters on the bottom. Where did you get them from? I could watch them for hours.
Old Nov 7, 2002 | 09:14 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
how low can you go on the stock rear suspension before the watts link binds up too much.
paradas are available in a 205/45/15. I was thinking of getting these and the ground control coilovers to lower the car down further. With the 45 series I want to get the fender down to the tire lip.
Old Nov 7, 2002 | 09:30 PM
ioTus's Avatar
'84 5-letter
tire LIP or top of the tire? tire LIP would look rediculously low, assuming you mean the inside lip, btwn the rim and the tire......
Not sure on how low you can go. I wanna go as low as possilbe tho.
pfsantos
Sep 30, 2015 01:29 PM
