UPDATE: boging and no power
hi, i just wanted to post an update for anyone who cares for diagnosis purposes. last week i posted that i was having a hesitation problem that was getting worse it started as a small hesitation at 4k, 5k and 5.5k then grew to an anoying level where i couldn't even get past 3.5k with out the feeling i was riding a bull. well, long story short sniper x (thanks)though it was the boost sensor so i replaced (thanks to bonzaitoyota)with a slight improvement but, it did not fix my problem although now i can actually get to 5.5k with a little throtle modulation. so after i put in the boost sensor i checked my tps and viola! i have not WOT signal on my tps so i have a tps on the way that i hope works (thanks to turbo 3) and i will see if that fixes my problem i'm pretty sure it will solve the hesitation so that's my tale of whoa! just though i'd share incase any of you are having the same type of problem.
thanks
james (sorry so long)
thanks
rgordon1979
40
Mar 15, 2022 12:04 PM
