Blitz FMIC japenese instructions= need help.
Old Jul 10, 2002 | 05:21 PM
From: Minnesota, now in FL and I dont think I'm goin back
Does anyone have the instruction manuel for the install of a blitz FMIC. Or some tips would help I know some of you have this FMIC.
Mike
Old Jul 10, 2002 | 06:01 PM
GoRacer's Avatar
Speed Mach Go Go Go
Arrow El Searcho searcharini surchinski
https://www.rx7club.com/forum/showth...ght=blitz+fmic
Old Jul 10, 2002 | 08:52 PM
IgoSlow's Avatar
follow the pictures.. thats what i did pretty easy to install... YOu have to cut the stock radiator mounts and put on the custom mounts they have so you can repostion your radiator to sit vertically.. Good luck to you. try contacting blitz for english instructions.. My friend got english instuctions from them on the blitz sbc controllers.
Old Jul 11, 2002 | 11:38 AM
NewbernD's Avatar
Tequila? ..it's like beer
Yep, taking your time and interpreting the pictures gets you most of the way there. Creativity will take you home. If you have specific questions about stuff in the instructions, let me know.. I'm bored at work and can go through some of the stuff with you.
Dave
Old Jul 12, 2002 | 01:59 PM
I though the Fluidyne would still sit in somewhat of a stock position, so it will get mounted vertically? I contacted Blitz and they said they dont have the software or some **** to send me US instructions.
Mike
Old Jul 12, 2002 | 02:34 PM
NewbernD's Avatar
Yep, it's definitely more vertical that the stock location. The intercooler is going to be sitting up front now. Dnd don't sweat it about the instructions. Remember that all of the brackets are stamped with part numbers, and these are in the instructions. Just budget yourself a weekend to do it and don't get frustrated.
You'll need a sharp hacksaw, or a pneumatic cut-off tool to cut the radiator mounts.
You'll have to have your AC system evacuated first.. (The shop should give your your R-12 back to you when you're ready to fill it up.)
Go get a few gallons of distilled h20, and some coolant.
If you have a tube bender for 1/2" tube, that'll come in handy for bending the large AC line. I used 2 large (23mm) box wrenches.
Don't forget to bleed your radiator first, before you start the car up. It's easier to do it right, while it's cold, than it is to fight with it once it's hot.
You do have a smaller battery, right?
Old Jul 12, 2002 | 05:00 PM
OK my new ? is the mount that the radiator is on right now has two bolts. Those 2 bolts are on really super tight. Do I have to cut this mount. It is the mount that holds the radiator, the radiator has a little rubber piece connecting it to the mount. So How do I get that off. Alsodo I just bend the exsiting bracket to get the new radiator to sit more vertically, or does my Blitz IC come with new brackets for the IC? Oh and yea I have a smaller battery ( hawker ) thanks for the help Newbernd keep the suggestions coming!!!
Mike
Old Jul 12, 2002 | 05:15 PM
Blackbeast's Avatar
Blitz FMIC
The 2 rubber grommet just sit on the stock mount, push it and they will fall right out.
Blitz FMIC kit comes with radiator relocation brackets, but will come short for your Fluidyne, so you would need to somehow make your own bracket or extend them.
Timmy
Old Jul 12, 2002 | 05:23 PM
NewbernD's Avatar
Actually, I don't think you'll need new lower brackets. My Koyo fit fine in the lowers (and it's thicker than the fluidyne).. It's the upper bracket, on the passenger's side that'll have to be made.
Yep, they're on there good but it's not SO bad. Put some *** into is. You can probably put on a box wrench and smack it with a hammer is you don't have enough leverage. It's these that you have to cut. Look at the pictures with the arrows in the instructions. They go from big pieces to little. Little is after they're cut, so make them look like that. And no, no need to bend anything.. it'll fit fine. Just bolt it up like is in the instructions, and all will become clear.
Old Jul 12, 2002 | 06:42 PM
OK since I am doing one little thing at a time then coming on the forum and posting here is where I'm at now. The old radiator is out, everything is perty much disconected. Now I am trying to figure out where to cut the old brackets that held the old radiator in place. It all is starting to become more clear, but keep the tips coming. SInce I am doing this by myself you guys are the only support I have right now.
Mike
Old Jul 14, 2002 | 07:45 AM
NewbernD's Avatar
Cut them like the pics in the instructions.
Old Jul 14, 2002 | 09:29 AM
OK now the new radiator is in =-) Now I have more ?'s There is a bracket that attaches to the top of the radiator, but I cant figure out what that bracket screws onto. Its the one that looks kinda like an L. So right now it is just bolted on to the radiator. I am about to go out and bend the AC lines towards the radiator. ANy tips on this I heard this was one of the hardest parts.
Mike
Old Jul 14, 2002 | 09:59 AM
NewbernD's Avatar
If it's the piece that's about 8" long and 5" wide and kind of "cut off", that bracket won't fit right.. because your radiator is thicker.. This is the piece that you'll have to re-engineer.
The AC lines are pretty strong. The best advice I can give you on them is to take your time. I used the closed end of large box wrenches for leverage. If I were to do this again, though, I might invest in a tube bender first.
Old Jul 14, 2002 | 12:58 PM
where might you be able to pick up a tube bender? where did you bolt on that L bracket? Can you brake the AC lines if you arent carefull? Oh and in the Blitz kit there is red vacum hose where the hell does that go, and it looks like they give you another AC pipe wheres that go,or do you not have to use that stuff?
Mike
Old Jul 14, 2002 | 01:54 PM
NewbernD's Avatar
You can find them at various places.. home depot.. automotive stores...
I've still got the stock radiator in.. I ran into other space issues with the koyo.. but it bolted up like it should.. You can see a pic here if that helps.
The red "hose" is some wire that they suggest you lengthen the fan wires with.
The extra line is for the power steering line.. It will replace that long, curvy one that used to run in front of the radiator. You DID pull that out allready, didn't you?
Old Jul 14, 2002 | 05:33 PM
umm your supposed to pull out some of the AC lines I didnt do that. I just bent them perty damn good. I am just about to drop in the IC. should I do this with the raditator out?
Mike
Old Jul 14, 2002 | 05:43 PM
setzep's Avatar
Mike
Off topic but is your FD silver with some aftermarket wheels? If it is I think I saw you driving it a few weeks back down highway 5 in burnsville. Nice ride
Cam from Lakeville
Old Jul 1, 2003 | 07:30 PM
evot23's Avatar
Classy
Did you take any pics of your install. I need to see bracket locations and mounting. I don't have ANY instructions. If you can show me some pics or even send me some instructions it would be greatly appreciated. Blitz was very unhelpful when I tried to get some from them.
Thanks!
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
