Haltech Haltech 3 Bar Map Sensor
Old Dec 10, 2001 | 04:33 PM
0piston's Avatar
Awhile back I was reading the Haltech list and there was a link passed for the 3 bar map sensor. Can someone please post a picture of the haltech three bar map sensor or just verify if this is indeed the same or compatible map sensor.
http://www.turbo-link.com/tlink/catalog/3bars.html
If it is the same, those of you wanting to get a deal you can purchase it there for $68. Haltech does use GM parts, just needed some verification...TIA
Old Dec 11, 2001 | 06:24 PM
Styk33's Avatar
Haltech E6K
Arrow
That is the GM sensor. If anything take a sensor that someone has from Haltech and measure the voltage at different pressures.
Old Dec 14, 2001 | 01:31 PM
Kurgan's Avatar
Gaijin Racing
The application for the 3 bar MAP sensor used by Haltech is from the US Spec 1989 Pontiac Trans-Am 3.8L turbo. It can be had from aggressively priced dealer parts depts for less than 60 dollars.
Old Feb 13, 2002 | 04:28 PM
Rotary93's Avatar
Retired RX7 mechanic
Kurgan,
Do you happen to have the part #?
Old Feb 14, 2002 | 10:26 AM
nd4spd's Avatar
It is GM part #16040749
Old Feb 14, 2002 | 12:05 PM
Heath's Avatar
MAGNUM SE7EN
So this is the exact same sensor as the Haltec 3 bar?
Old Feb 14, 2002 | 12:06 PM
Rotary93's Avatar
I found a place online that has it for $46.
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
