Arg! Need belt size so I can remove the airpump.
Old Oct 28, 2002 | 12:07 PM
Street King's Avatar
*** Bless Texas!
Question Arg! Need belt size so I can remove the airpump.
OK I have searched and I do not want to get the Greddy pullies. All I want to do is remove the airpump and use a normal belt without using pullies.
Ok I do know the belt size I need,(300mm 3-5 rib, 29 1/2" - 30 1/2" 3-5 rib), but at the auto stores around here they go by make and model not by belt size, so instead of taking the belt off and "eye matching" it(hate that) I need to know what car belts fit that size if any.
Thank You,
Jonas
Old Oct 28, 2002 | 12:22 PM
ttpowerd's Avatar
HARRRRRRRRR
I think you need the greddy pulleys because the water pump pulley will be too small to get enough friction to turn. Why don't you want to get them?
Old Oct 28, 2002 | 01:23 PM
*** Bless Texas!
Because it's a part that's not neccesary for me to spend $200.00 on when I cna go about it a different way. Alsp going through pending court cases that will eat up my money so every little bit helps.
No you can remove it with out the kit. Buy a 290 or 295 k4 belt and see what fits the best.
Hey thanks that's the answer I'am sorta looking for, except do I just go in and ask for a 290 or 295 k4 belt(will they know what I'am talking about)? Is that off the K series trucks?
Old Oct 28, 2002 | 02:27 PM
reza's Avatar
I have a belt from Greddy Pulley Kit.
Will it work for him? I am selling it.
Reza
Old Oct 28, 2002 | 02:29 PM
*** Bless Texas!
Reza
Not that I know of.
Old Oct 28, 2002 | 02:41 PM
93blackrx's Avatar
dude....
Just take a long string and wrap it around the stock pullies. take that lenght and get five rib belt from your local car parts store. I've got a 29 inch that i used for about a week. I have the greddy kit though, If you think that the 29 incher will work I'll sell it for 10 bucks. hope that helped.
regards, Matt
Old Oct 28, 2002 | 04:04 PM
*** Bless Texas!
Originally posted by 93blackrx
dude....
regards, Matt
Did the belt that you used for a week have any problems?
Old Oct 28, 2002 | 05:33 PM
7-sins's Avatar
thats not paint....
Originally posted by Dont_Be_A_Rikki
its a 4 rib belt 290, 295 mm. it is a tite fit so use a flat head to get it on the pulley if you have to.
-Rikki
I think I used a 295K4 like Rikki was talking about and it is a TIGHT fit. Pullys would be nice but for now this belt works. 300K4 is what you need I believe but its extremely hard to find in any auto parts store.
Old Oct 28, 2002 | 09:31 PM
c00lduke's Avatar
i couldnt find any 4 ribbed 29.5" so i used to pimp 3 rib, worked nicely
Old Oct 28, 2002 | 09:49 PM
Flybye's Avatar
It's never fast enough...
I got the 295K4. I don't think anyone makes a 295K5, and the 305K5 was TOO long. I don't think that sucker is going anywhere. I've driven with that belt almost 10 times and have taken it up to 6-7k.
I didn't go with the Greddy pulley also because I read it slows down your waterpump. Sure, it's function IS to slow down your accessories and remove the airpump, but I have this thing with slowing down the waterpump itself....
Old Oct 29, 2002 | 03:50 AM
rx7_lover's Avatar
hmm... this is what i was looking for.
remove the airpump but keep the stock pulleys. so 295K4 or 295K5?
Old Oct 29, 2002 | 04:10 AM
skunks's Avatar
I'm a CF and poop smith
remember, with the string trick, you gotta add a bit more cuz the belts they have measure from thetop of the pullies instead of in the ribs.
good luck
Old Oct 29, 2002 | 04:56 AM
duboisr's Avatar
The water pump will cool better if you slow it down .The water will have time to pick up more heat and more time for the rad to remove the heat. Also the pump will not cavitate at high speed, that is the main reason.
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
