Electronics Guru's Please help!!!!
Ok, The problem is that I decided to rewire my fuel pump and with little background in electronics I was abit scared of the results. However I did it! Well some what anyway, I did it according to 1300cc.com site. By the way its a really good and user freindly site, But somewhere along the rewire I must have done something wrong because when I thought I was done I went to reconnect my battery and all of a sudden the fuel pump comes on, this happened without the key in the ignition or the jumper wire in place! Any idea whats going on? What wires I might have crossed? I have looked over this countless time and everything looks to be wired up wright! I just need some imput on what to check,relay ,resistor?I have already searched this forum for hours trying to figure out what went wrong, came up empty handed every time! Any help would be greatly appreciated! Oh, the car is a 10th AE!
Its a 30amp 4 prong Auto relay from Radio shack. However I sure I have a wire in the wrong spot. This is how I have it set up!
86=stock fuel pump pos
85=stock fuel pump ground
87=10gauge from battery
30/51=ground to E&A
This is according to the back of the resistor!Maybe this will help!
30/51=ground to E&A
yours sound wrong.
if you have a box or something that says which each # is for post it up. I can't seem to find any sites online that say what it is.
edit:
I think you want
30 battery
87 to resistor relay
85 old pump pos
86 old pump neg
85 / 86 can be swaped around
30 / 87 could too I think
with your setup now the relay should have the pump on all the time. since it is. everything else is probably right
edit:
I think you want
30 battery
85 old pump pos
86 old pump neg
Originally posted by 7'sfalife
Ok according to the box it says
86=on/off switch 12v
85=ground
87=12v in
30/51=12v out
85=ground
87=12v in
30/51=12v out
86 stock wire pos (which turns (switches) the relay / on off when ever stock pump had power)
85 stock wire ground = ground
87 battery = 12v in
30 to resistor relay (12v out to fuel pump, passing though other relay first)
hopefully you can understand that now as well just being able to hook it up
Trending Topics
Ok so I had it wired good the first time which tells me I messed up somewere else! Its still doing the same thing so let me see if I can switch some wires around and get it wright! I appreciate you help scott, any other thoughts?
the "c" speaker wire will have 12v "when the pump is running". not sure about D it might.
however it should only be running with the key in and the jumper jumped. or car running.
the problem seems to be upstream more
so as soon as you connect the battery. the pump turns on? this is correct? with no key or jumper
check the stock pos wire running into the relay for 12v. it'll probably have it. but it shoudln't.
knowing that will help narrow it down though.
hmm... well it's not the relay then. you must have the wiring at the resistor relay wrong and the speaker wire is giving it power.
edit: wait that doesn't make sense either since the speaker wire shoudln't have 12v untill the key is in either.
hey that's pretty sweet
I would recheck over all your colors at both ends with those 6 wires.
on the top as long as you have both blue/reds with blues it's ok. doesn't have to be the exact one with the exact one. since it's impossable to tell after cutting the plug away.
I think it's possible that "C" will always have power on an 87-88 car after some more looking. it won't on an 89-91.
I would recheck over all your colors at both ends with those 6 wires.on the top as long as you have both blue/reds with blues it's ok. doesn't have to be the exact one with the exact one. since it's impossable to tell after cutting the plug away.
Ok I made a mistake, Only one of the speaker wires is seeing the 12v, does that help any?
now check the connections vrs color from above. you probably have one wrong.
Ok I noticed that the relay on the chart is a 5 prong should I have gotten one of them instead? Also the 30 on mine is going to E&A and 87 is the battery wire,would this cause it to stay on like this!
you can reverse those 2. it's fine. you only need 4, hence why nothing is on the 5th. some are 5.
your relay is working because you don't have 12v comming out of it with the key off.
my best guess is your speaker wire is turning it on.
so check those 6 wires at the front and back and see if the colors are connected together right.
Ok I noticed that the relay on the chart is a 5 prong should I have gotten one of them instead? Also the 30 on mine is going to E&A and 87 is the battery wire...
The way I've shown just seems to be the convention. The input power goes to 30, and the output to the device being switched is connected to 87.
The fifth terminal in the middle is 87a, and some relays don't have it. With 5-pin relays the power goes from 30 to 87a with the coil off and from 30 to 87 with it on. You do not need a 5-pin relay for this mod.
Originally posted by RunningDeer
gheez Jason, I am impressed.. excellent piece of work
Adaptronic MTX-L to adaptronic question
TeamRuffRacing
Sep 30, 2015 08:13 PM
Thor 18
Sep 28, 2015 07:35 PM
