whos gas light still works?
Old Oct 24, 2002 | 02:19 AM
goblues24's Avatar
i recently did all the resoldering jobs on my vert but i still cant get my low fuel light to work right. my series 4 86 sport's fuel warning light broke shortly after i purchased it, also.
everyone chime in and tell me....do you have a fuel warning light that operates properly?
Old Oct 24, 2002 | 02:25 AM
13bpower's Avatar
s4 for life
Mine still works like new!
Old Oct 24, 2002 | 03:46 AM
tweaked's Avatar
I ahve three of these and I didn't even know they had such an beast
Old Oct 24, 2002 | 03:47 AM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Multiple answers
'85 SE - Works cause replaced with wrecking yard part.
'88 Vert - Works, always has
'91 Vert - Never worked.
'91 Auto Vert - Never worked
'88 with S5 Gas tank retrofit - Never worked
So, I'm wondering if this is a weak link for S5's?
Here is the real challenge. What is the Mazda Part Number for the "silver bullet" sensor mounted on the end of the long wire like mount... aka THE SENSOR???
Once you pull the fuel pump/sensor assembly out of the gas tank, its a simple one or two screw away from being replaced if that part were in hand.
So, I say again. The real question here is what is the Mazda part number for this little trouble maker???
Old Oct 24, 2002 | 03:48 AM
HOZZMANRX7's Avatar
So, not to be missed.....
What IS this little jewel of a sensor part number? This is one repair that is driving me nuts to figure out how to do.
Old Oct 24, 2002 | 03:53 AM
bingoboy's Avatar
Lava Surfer
there's a gas light?
Old Oct 24, 2002 | 04:25 AM
hIGGI's Avatar
mine is almost all time ON :o)
Old Oct 24, 2002 | 07:38 AM
presetlimits's Avatar
mines an 88 ...works good as new, was on just 5 min ago on the way too school thought i was about to run out of gas
Old Oct 24, 2002 | 07:41 AM
Rattaan's Avatar
we...yota...
Mine works on my '90 just fine. I can even tell that the sensor is on the driver's side because it comes on with about 1/4 tank and a good hard left turn
Old Oct 24, 2002 | 07:46 AM
Nick86's Avatar
Yup, still here
Well, when you park your car on an angle like this, it might effect your fuel level readings! just kidding.
Mine has always worked......knock on wood.
Old Oct 24, 2002 | 07:56 AM
Rxmfn7's Avatar
Do a barrel roll!
Mine works sometimes, so does my clock and the rest of my idiot light cluster. Seems to just work whenever it feels like it. Guess Im due for a soldering job......
Old Oct 24, 2002 | 08:01 AM
hahaha
Old Oct 24, 2002 | 08:17 AM
silverrotor's Avatar
Mine still works too.
Old Oct 24, 2002 | 09:24 AM
Jodoolin's Avatar
HozzmanRX7 - the "sensor" at the fuel pump is at Section 2 G9 of the Parts Catalog. It is part number 60-960A. Called "Gauge, Fuel Tank"
Presumably it feeds the dash gauge. There must be a split off the gauge itself based on the position of the needle going to the idiot light but I could not find it . Hope this helps.
Jerry
Old Oct 24, 2002 | 09:48 AM
Wankel Traitor
Mine worked great in my 88 GTU, and it doesn't work at all in my S5 TII. My gas gauge works fine, just the light never comes on.
Jameson
Old Oct 24, 2002 | 09:53 AM
Josepi's Avatar
Despise Enmity
Old Oct 24, 2002 | 10:34 AM
seventhgear's Avatar
boost on the way(GTU II)
MINE WORKS I GUESS. IM LOW ON FUEL AND IT FADES IN AND FADES OUT HEY I GUESS IT WORKS! sorry for caps
Old Oct 24, 2002 | 10:40 AM
GXL like a mofo
My low gas light works, and I think it works all the time (usually gas it up at 1/4 tank), and the rest of my idiot cluster works too....
Old Oct 24, 2002 | 10:45 AM
Xentrix's Avatar
Kill Bear
mine fades in and out for a bit then when it stays on all the time I can get around 20 miles in.
Old Oct 24, 2002 | 10:46 AM
faster7's Avatar
Mine work
On the 2 of my FC's I've ever had batteries in, and the friend's car I've had borrowed the last 2 weeks works great as well.
R
Old Oct 24, 2002 | 11:05 AM
jimmyv13's Avatar
Round&Round not Up&Down
did not work in the 85 GSL
worked in the 86 NA
works in the 87 TII
Old Oct 24, 2002 | 11:06 AM
vmb
that part # is invalid
Old Oct 24, 2002 | 11:08 AM
Thaniel's Avatar
Mine has never worked since I owned the car. All the other guages etc work. Never spent any time looking for why it doesn't work.
Old Oct 24, 2002 | 02:05 PM
bcty's Avatar
Boost This!
mine works... thank god cuz my fuel gauge doesnt..
Old Oct 24, 2002 | 02:28 PM
HOZZMANRX7's Avatar
Question
Jodoolin....Thanks for the attempt. But, can you (or any one else out there) help clear the confusion further.
Even though they are two separate parts mounted separately, it looks like you have to buy the "gas level float sensor" as well as the "low fuel sensor" as one unit?
