how do you swap a s5 maf onto a s4 car?
I "lost" my emissions....
i know a friend who did it, but i cant get ahold of him now. the s4 afm has 7 pins, the s5 maf has 5, whats up with that?
im guessing a power wire
ground
temp
af
then what?
and what wire do i need to swap to what?
ground
temp
af
then what?
The S4 AFM has a fuel cut switch built into it. You will need to cross those 2 wires together to allow the fuel pump to run. Those wires are Black and Brown and both are at one end of the S4 connector. I forget in my testing but I do believe once those wires are crossed and the IGN ON, the fuel pump is running. So I don't believe there is a way to have the fuel pump shut off besides turning the IGN OFF
S5 Connector Wires connected to S4 Harness Wires
Green / Orange to Green / Orange - AFM IAT sensor
Two Brown / Black to One Black - 2 Grounds, One for IAT and one for Vari Resistor. The S4 AFM has the one ground split in the AFM. The S5 has two seporate grounds.
Brown / White to Brown / White - 4.8v+ to Vari Resistor & AFM IAT
Green to Green / Blue - Vari Resistor Output (Cone Position)
I have never done this before so I don't know the outcome.
In that picture, they jump the fuel pump cut off switch terminals which won't do anything. You have to cross the wires.
