99 spec oem rear spoiler
Old Dec 1, 2007 | 11:42 PM
badddrx7's Avatar
All Spooled Up
Anyone know if an installation sheet exists out there anywhere showing an OEM 99 spec being mounted? Or if Ray Crowe might have access to the mounting hardware. I just bought one and noticed a slot for one mounting fastener, I believe it is on the driver side. Also the two outer bolt bosses are for 6mm bolts and it looks like the inner fasterners were studs ? Anyone who has actually mounted a new oem 99spec rear spoiler - pm me.
I can mount it, just curious about the factory method they used.
thanks,
Old Dec 1, 2007 | 11:53 PM
tafkamb2's Avatar
ive seen it somewhere it uses the same mounting locations as the other stock one except one less hole.
Old Dec 2, 2007 | 10:33 AM
badddrx7's Avatar
All Spooled Up
Anyone else ?
later
Old Dec 2, 2007 | 11:02 AM
cliprun's Avatar
spoiler
i like the look tho
Old Dec 2, 2007 | 11:15 AM
ObliqueFD's Avatar
http://www.negative-camber.org/crispyrx7/99wing.htm
Unfortunately the website is down right now.
Basically, what you can do is get a piece of clear plastic, lay it on the underside of the spoiler and mark the location of the studs. It's not that accurate, but it should work if you take your time and measure everything.
Old Dec 2, 2007 | 03:01 PM
badddrx7's Avatar
All Spooled Up
I won't have a problem making a template, I just need to know what fasteners did Mazda use for this slot and 3 other threaded bosses. Look at my photos. the outer boses are no problem, they take 6mm bolts and some gaskets. How about the inner 4 mounting areas ? Love to see a OEM mounting instruction sheet. Anyone got one ? Take a pic and post it if you do.
later
Attached Thumbnails 99 spec oem rear spoiler-dsc02244.jpg   99 spec oem rear spoiler-dsc02243.jpg
Old Dec 2, 2007 | 07:02 PM
FDNewbie's Avatar
Sponsor
Hey Tom,
I don't have the actual installation instructions, but I can definitely tell you that while the mounting hardware is not available from anyone in the US, I can readily obtain it for ya from Mazda Japan. In fact, I just bought a set of the mounting hardware for Heath (RotorMotor). I'm sure he can post pics of the parts if you'd like...
Thanks!
~Ramy
FDNewbie Imports
Old Dec 2, 2007 | 08:57 PM
badddrx7's Avatar
All Spooled Up
Ramy, I emailed you
I was hoping you'd respond. Tell me what the hardware package contains and how much shipped to me in ohio.
Yes Heath, Pictures would be great
thanks Ramy
later
Old Dec 2, 2007 | 09:23 PM
FDNewbie's Avatar
Sponsor
Tom, we'll have Heath post up a list of what's included in the kit, that way you can see what you need and what you don't and we can go from there. Sound good?
Old Dec 2, 2007 | 10:27 PM
Triperformance's Avatar
+1 for the FD brotherhood! The FC crowd seems to be a little stiff around here, anyways congrats on picking up the wing I want on mine!
Old Dec 3, 2007 | 04:13 AM
badddrx7's Avatar
All Spooled Up
Sounds good Ramy. Thanks
later
Old Dec 3, 2007 | 10:44 AM
FDNewbie's Avatar
Sponsor
Old Dec 8, 2007 | 04:01 AM
badddrx7's Avatar
All Spooled Up
Aybody else have any info ? Installation sheet, etc ?
thanks
Old Dec 8, 2007 | 08:31 AM
DaiOni's Avatar
Wankler
fwiw,
Old Dec 8, 2007 | 11:14 AM
badddrx7's Avatar
All Spooled Up
DaiOni is the MAN !! Great work. This is EXACTLY what I was looking for. I see now what I suspected all along - two of the inner fasteners are the pop-in plastic type like a door panel has. Now it adds up.
Dai - I'd sent you a pm, see if you can help me a little more.
Again, great work. Good info for anyone mounting a OEM rear spoiler
later
Old Dec 8, 2007 | 11:25 AM
badddrx7's Avatar
All Spooled Up
DaiOni - Here is the parts I need:
51-973B weatherstriping - need two of them, one for each side cover (total 4 pieces)
51-966 weatherstrip pedestal - need two of them, one set for each side
51-966B #2 Two of these
51-966B #1 Two of these
51-958 #1 two of these
51-958 #2 two of these
99940-0603 two of these
9Yaa2-0601 two of these
and an instruction sheet IF possible.
If you can get these, then send me a total to blueyes01@adelphia.net and I will paypal you right away.
thanks
Old Dec 9, 2007 | 10:39 PM
badddrx7's Avatar
All Spooled Up
I am trying to find someone that can halp me order these parts from Japan. Ramy, do you have time to contact me or does anyone else know of someone who has contact with Mazda in Japan that can get these for me ?
Trying to mount a 99spec the right way
thanks
Old Dec 9, 2007 | 11:10 PM
FDNewbie's Avatar
Sponsor
thanks
Tom, yea I can order 'em no prob, but I thought I'd sit this one out given that you went from askin me after I told ya I could get 'em to askin DaiOni lol. If you want me to order the parts for ya, cool; I can do it no prob. Just pick one person/vendor lol. And I don't mind who it is; DaiOni's a great guy
Thanks,
~Ramy
Old Dec 9, 2007 | 11:52 PM
jackie01's Avatar
Newbie
Thanks for your Pm. I will try my best to Locate your item. I am willing to know that you need Rear Wing Spoiler Like in the pictures? If not then send me complete information about item. http://www.hediko.com/99SpecRX-7Wing.jpg
Thanks
Old Dec 10, 2007 | 12:13 AM
badddrx7's Avatar
All Spooled Up
Ramy - email me at blueyes01@adelphia.net if you have time to order these parts for me. I emailed on the 2nd you but no reply yet.
thanks
Old Dec 10, 2007 | 01:04 AM
FDNewbie's Avatar
Sponsor
Tom, yes I def. have time to order them for you. I didn't reply to your email b/c I replied to your post here. No sense in replying multiple times. I was waiting for Heath to post up the parts list I provided him with, as it appears you don't need all the parts; just a few. He hasn't posted yet. But DaiOni was kind enough to post up the parts diagram you were looking for.
In any case, I emailed you.
Thanks,
~Ramy
Old Dec 10, 2007 | 11:14 AM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
Ramy,
I might need some too if you don't mind..
Maybe I could split shipping with Tom..
I need the following.. 4 x 51-966
I need to replace that as mine are worn out.
Old Dec 10, 2007 | 04:28 PM
FDNewbie's Avatar
Sponsor
Phil, sure...jump on in. I was thinkin of gettin a GB goin on them b/c ppl are ALWAYS askin about these parts...
Old Dec 10, 2007 | 04:49 PM
Herblenny's Avatar
Cool! Let me know Ramy! I'll get couple of set of them I have 2 weeks off in 2 weeks and going to work on my car to get it all done!
Old Dec 10, 2007 | 05:29 PM
FDNewbie's Avatar
Sponsor
Phil,
You mean you wanna jump in on this order and get a few? If so, how many?
Or do you mean you wanna wait and see if we can get a GB going?
