Where To Buy Antenna Adapter For 3rd Gen???
I have a 93 RX and I just tried to install my Clarion DRX7475 CD player and I found that the antenna adapter is slightly odd. It requires two male ends to plug into the factory side and a male end to plug into my CD player. Anyone run into this same problem? Know where I can find this item? I tried Best Buy and Circuit City and they just looked at me stupid and said they do not have anything like that. Am I overlooking something here? Thanks for the help.
goto radio shack and look in the section with the antenna adapters and they'll have it. If I remember correctly from my install you only use one of the factory connectors, so the one you need from radiochack will have one male end on each side.
damn this thread is old, but i'm having issues with this. i'd like to connect both the hatch and telescoping antenna into a aftermarket HU but it takes a lot of adapters:
motorola male to motorola male
proprietary ford/mazda male to motorola male <---impossible to find so far
motorola 2 female to 1 male motorola
i'm considering butchering the existing antenna leads from the factory headunit to make the male to male that i can't find from above. seems like the only option.
DC5Daniel
60
Aug 11, 2016 10:00 PM
