rotor swapability
Originally posted by wwilliam54
you need to use a front and flywheel counterweight that matches the rotors tho
Also more related info from RX-7 Forum > Tech and Performance > General Rotary Tech Support forum
Originally posted by rgordon1979
I am in the process of rebuilding a '88 TII engine. In the process of finding a new rear rotor and housing I came across something I have never seen on here before.
As you know, Mazda balanced each rotor at the factory. Due to slight variations in the balancing process, each rotors weight varies slightly. Mazda designates this variation by stamping a letter, (A-E), on the gear side of the rotor. According to Mazda the rotor weight should not vary more than 2 letters in an engine. Ideally, you should have matching rotors. I did verify this with Henry at Mazdatrix. If this is common knowledge, sorry to take up the bandwidth, just wanted to let everyone know.
Rob
Rob
The geometry of the post '85 13b rotors had different geometry (unsure of the 4-ports, but different from GSL-SE 13b 6-ports). They will work, but you will have a risk of them coming into contact with the rotor housing at high RPMs.
Ask a place like Mazdatrix for information about this.
20B Forum
Sep 22, 2015 07:39 PM
