What is the other plug for, on the oil pressure sender?
Old Jan 10, 2003 | 02:53 PM
Samps's Avatar
After doing some electrical work. I noticed that the wire that goes to the oil pressure sender "y"s off about 6 inches downstream. It connects to that other little plug that sits right above the sender. What is this plug and wire for? It has a yellow wire with red stripe I believe. The plug is a single wire connector. Looks like it is just connected to the upper intake manifold with a resistor or something of the like.
91 vert
Old Jan 10, 2003 | 03:12 PM
HAILERS's Avatar
HAILERS
Its a condenser. I've found the gauge works the same with or without it. Prefered method is with. Jpg attached if the site will support it:
Old Jan 10, 2003 | 03:25 PM
Samps's Avatar
Thanks HAILERS! I though maybe it was a resitor to calibrate the same oil pressure sender in all FCs with the different guage clusters. What is the condensor supposed to do? And why did Mazda put it on the UIM? Seems like it would have been alot easier to just put it inline with the sender wire.
Old Jan 12, 2003 | 11:32 AM
HAILERS's Avatar
HAILERS
I really don't know. IceMark might know. I'm not electrical in nature.
The1Sun
Mar 18, 2018 11:08 PM
Snoopy FD
Dec 8, 2015 01:45 PM
20B Forum
Aug 18, 2015 02:46 PM
