Greddy IC & Intake - URGENT! Professionals Needed for Answer!
Old 02-26-03, 10:00 PM
apneablue's Avatar
Nothing of the sort I just think it's a hoot to see threads with the topic "Urgent help needed for dropping boost!" stuff like that...
Anyway, on to my original question.
I am wanting the Greddy 2 Row kit but now have the Apexi Intakes. From what I have read the Apexi intakes need to modified to work with this IC. How does it need to be modded and do you think it would be better to just buy the Greddy Intakes that fit with it?
I also wanted to get the intake hardpipes for the apexis but only if the modification of the Apexis aren't too difficult and time consuming. If it is the greddy intakes come with teh hardpipes...Soooooo, help me make a decision would ya
Old 02-26-03, 10:04 PM
Mr. Links
Mahjik's Avatar
Arrow
Check here:
http://flathat.woodstream.net/RX7/Docs/Greddy_FMIC.html
Old 02-26-03, 10:38 PM
Tomco78's Avatar
I have the GReddy2-row FMIC and GReddy intakes, and even that is a tight fit...
Old 02-26-03, 10:54 PM
apneablue's Avatar
so who has the two row and what intakes are you using? thanks Tomco.
Old 02-27-03, 04:50 AM
SleepR1's Avatar
nocab72 (Kyle Bacon) has the 2-row with Apexi intake. Apexi hard pipe intake kit only comes with the Apexi FMIC kit, but he does NOT use the Koyo, he uses a Fluidyne (which has a thinner core). If you're using a Koyo, no other intake will fit other than GReddy dual intake kit (I'm assuming you have twin turbos?).
I use the GReddy dual intake kit with my 2-row. The lower rad hose for the Koyo was modified to use stainless steel flex hose to allow room for the lower intake mushroom filter to fit (just barely!).
Old 02-27-03, 12:15 PM
Rebreaking things
CCarlisi's Avatar
I stuck 2 K&N filters on the turbo inlets themselves eliminating all the hoses ect. It was under $100 and spools up nice and fast now
Old 02-27-03, 12:19 PM
apneablue's Avatar
Care to elaborate a bit more? what did you do with the extra hoses? and do you have any photos? thanks....
Old 02-27-03, 12:25 PM
Cihuuy's Avatar
CCarlisi: would like to know too... how the hell did you eliminate all the hoses?? doesnt dat suck hot hair to the engine??
Old 02-27-03, 12:39 PM
apneablue's Avatar
This is the only BLITZ FMIC pic I found that looks like it's working with the Apexi intakes just fine....BUT the pic is so much from the front I really don't know for sure...does anyone know whos car this is and if there are engine bay pics?
Old 02-27-03, 12:41 PM
apneablue's Avatar
Just so you know, the BLITZ is my second choice...will be my first choice if it fits flush with the Apexis..
Old 02-27-03, 01:03 PM
mjw
mjw's Avatar
That silver car is mine, the Blitz fmic works fine with the Apexi intakes. I didn't have to cut or modify anything for them to work. But that bracket that ties the two intakes together at the top can't be used anymore.. which was fine with me because it made them difficult to work with. The uppermost intake that makes the 90 degree turn toward the center of the car, that one needs minor repositioning but the bracket for it still works fine (the one that bolts onto the crossmember). Not sure about the Greddy fmic, I know the Blitz is much easier to install.. you can't go wrong with either one though.
Matt
Old 02-27-03, 01:10 PM
apneablue's Avatar
Hi Matt, you are like a God send to be honest...you know when you search and search and still can't seem to find an answer? anyways, thanks...
Another question is, I want to buy the intake hardpipes for the Apexis as seen here on the rx-7 store webpage...will the intakes with the hard pipes work with the Blitz FMIC? and if you have any engine bay photos post those beauties would ya!
thanks again.
Old 02-27-03, 01:18 PM
It has begun
lane_change's Avatar
I don't think I have any pics of mine but I ran the Blitz FMIC and Apex'i Intakes as well. Just like someone said above the bracket that goes between the two intakes will not work anymore. The other two brackets just have to be custom fitted to bolt to the crossframe. I used a zip tie to hold the two intakes together. I am not sure if you can use the hardpipe kit like M2's since it makes the intake sit in a certain position, where as the factory pipes are flexable and you can bend them a little to make the intakes fit without rubbing. If I have any pics I'll post them.
Old 02-27-03, 01:44 PM
STi Boxer power!
Scrapiron7's Avatar
I am using the Greddy Intake with a Greddy 2-row FMIC. It's a tight fit to get everything in there but it looks nice when it's done. I will try to get some pics up tonight.
Old 02-27-03, 01:59 PM
Rebreaking things
CCarlisi's Avatar
I bought 2 K&N filters from baker, one with an angled mount and one with a standard mount. These are the same filters used in the pettit kit. I took off the stock airbox and the black rubber tubes that connect it to the turbo inlets. I connected the straight mount intake to the turbo closest to the firewall. The front turbo was a little more difficult to attach the hose to because there is not a lot of room for the filter. I positioned the filter with the curved outlet under the airpump and against the passanger side fender(think it's right in front of the shocktower, but can't remember off hand). There was only about 1 inch of clearance between the airpump pully and the front filter. To provide additional clearance I crush in the part of the filter near the air pump another inch. This is easy to do because the filter has a bendable steel mesh.
Yes it does suck in hot engine air, but I'm not convinced that the apexi, greddy, re or pettit filters do much better. When I have more time I'm going to try to fab a custom box that will draw air from the top of the hood, or the fender liner.
Old 02-27-03, 02:00 PM
mjw
mjw's Avatar
thanks again.
No problem, glad to help. I know exactly what you mean about not finding answers you need, when I bought the Blitz IC I already had the Apexi intakes and wasn't sure they would work. I had a picture of the Blitz piping that I just kept studying and convinced myself that it would work. Luckily it did.
I'd take a picture of my engine bay for you but it would do you no good anymore, the twins are no longer. I will look in my picture archives when I get back to my place tonight and see if I still have one around.
Old 02-27-03, 02:02 PM
Rebreaking things
CCarlisi's Avatar
Yes it does suck in hot engine air, but I'm not convinced that the apexi, greddy, re or pettit filters do much better. When I have more time I'm going to try to fab a custom box that will draw air from the top of the hood, or the fender liner. I'll put some pictures up if I ever find the adaptor for my digital camera :p
Old 02-27-03, 02:22 PM
apneablue's Avatar
And another thing...does the BLITZ piping fit the the greddy elbow or is there a way to do it?
Old 02-27-03, 04:09 PM
mjw
mjw's Avatar
The piping does not fit the Greddy elbow, I had to get an extension welded on since the Greddy elbow is shorter than the stock one.
Old 02-27-03, 04:27 PM
apneablue's Avatar
Engine bay shot by newbernd
newbernd just PMed me his blitz setup thought I would share...
Old 02-27-03, 04:28 PM
apneablue's Avatar
damnit that didn't work
Here it is
Old 02-27-03, 04:29 PM
apneablue's Avatar
what the hell is going on?
here it is
Old 02-27-03, 06:32 PM
SleepR1's Avatar
Sucking in hot underhood air doesn't matter if your FMIC core is huge. The huge IC core's efficiency in cooling intake charge air more than makes up for the hot underhood intake air. Air intake speed and volume matters more than air temperature, and the GReddy Airinx does a good job with intake speed and volume.
Pics were taken by Zavier Neeley and Jason Baughman of Rx7 Store. The hard pipe with the dent was replaced. The R1 strut brace was not installed yet.
http://66.216.67.51/images/products/...ar/engine2.jpg
Speed Sauce Racing Rx7 R1, under contruction @ The Rx7 Store
http://66.216.67.51/images/products/...ntercooler.jpg
http://66.216.67.51/images/products/...cooler-rad.jpg
http://66.216.67.51/images/products/...enginedrop.jpg
http://66.216.67.51/images/products/...car/engine.jpg
trickster
07-01-23 04:40 PM
Quick Reply: Greddy IC & Intake - URGENT! Professionals Needed for Answer!
