thread pitch going into brake MC
Old Jul 18, 2008 | 01:54 PM
boostedHULK's Avatar
are the thread pitches on the SA different at the MC/dist. block as well? had to order some new lines for the rear end swap and was looking for some options to swapping in this other distribution block and/or Master Cylinder...trying to come up with a combination to work without ordering anymore lines i have to have made. The company made me a great DOT approved line, but i'd prefer not to have to spend the cash.
Old Jul 18, 2008 | 02:25 PM
j9fd3s's Avatar
Community Builder
afaik the SA's are 1.25 everywhere
Old Jul 18, 2008 | 02:55 PM
i'm pretty sure also, i had a chance to take a look at it. Does anyone have a good idea for fixing this problem without having to make all new lines? i was kinda leaning towards an aftermarket proportioning valve.
Old Jul 18, 2008 | 07:51 PM
7aull's Avatar
RX HVN
Mazdatrix sells a stainless steel line rear hose kit for the FB/Disc that can include an adapter hose to the existing SA rear hard-line, so no SA lines need to be swapped except soft line at back axle junction-
Stu Aull
80GS
Alaska
Old Jul 19, 2008 | 01:02 PM
i have that part finished. we're talking about the master cylinder and distribution block. The dist. block for a disc brake rear is different.
Old Jul 19, 2008 | 01:20 PM
Rogue_Wulff's Avatar
Too old to act my age
The easiest way around this, would be to use the FB hard lines all through the system. Of course, you'd need to swap to FB front calipers and mounting brackets as well.
FYI, the clutch hydraulics have the same thread pitch as the brakes.
Old Jul 19, 2008 | 05:59 PM
1stgen4life's Avatar
Leaking oil like crazy!
Re-Speed has just the line too if you don't want the whole kit.
mazdaverx713b
48
Apr 21, 2016 06:45 AM
FC_DREAMS
General Rotary Tech Support
Aug 30, 2015 09:12 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
GrossPolluter
Aug 16, 2015 09:50 AM
