how do i replace my cross threaded stud???
Old Feb 3, 2004 | 04:08 PM
gdnimr0d's Avatar
screwed by chad hall
well guys i have a cross threaded stud on the back right rear and i got started on replacing it today...so i removed my brake caliper and now the rotor is all thats left to remove i just dont know how to get it off so any of you guys that have done this yourself already please tell me what to do next thanks and peace out...oh yeah heres a pic of my current progress
Old Feb 3, 2004 | 04:11 PM
DCrosby's Avatar
No it's not Turbo'd
See the hole in the rotor ?? Put a bolt in there that fits, and the rotor will just "Pop" off....
The hole just to the left of the stripped stud....
This will push against the hub and free the disk
Old Feb 3, 2004 | 04:15 PM
gdnimr0d's Avatar
hmm alright i will gimp my way back out to the garage since i am doing all this with my ripped ligiment ankle no driving her for a month so this is why i started all this little bs tideous work on her haha well thanks i will reply back to let you know if that worked brb
Old Feb 3, 2004 | 04:16 PM
user 9348703's Avatar
did you start drilling it or something?
DCrosby's Avatar
No it's not Turbo'd
Okay, do me a favor, go easy on the submit buton
Old Feb 3, 2004 | 04:23 PM
gdnimr0d's Avatar
haha yeah my bad...well i just tried what you told me to do DCrosby and no luck are you sure i dont have to remove that big nut in the center of the rotor well let me know
Old Feb 3, 2004 | 04:39 PM
DCrosby's Avatar
No it's not Turbo'd
You found a bolt that fits in the hole next to the rounded stud !? And started tightening it !?? and Nothing ??? I can hardly belive it, use some WD 40 on the rotor... where it connects with the hub... but that usually works better than a welding torch to heat the disk... ??? WTF... make sure the bolt fits well and tightens... maybe use a breaker bar on the bolt you're putting into the disk....
DCrosby's Avatar
No it's not Turbo'd
Repost
Old Feb 3, 2004 | 04:40 PM
oakridgerx7's Avatar
take a hammer, and beat that thing out. there shouldent be any need in removing the rotor
Old Feb 3, 2004 | 04:41 PM
teamstealth's Avatar
Ozone Depleter
I was told it just slips out from behind. I have the same problem but been too busy/lazy to correct it so lemme know how it goes!
Old Feb 3, 2004 | 04:42 PM
gdnimr0d's Avatar
alright i will go and tighten it i thought you just wanted me to put a screw in and put weight on it to make it pop off alright i will let you know how that goes brb
Old Feb 3, 2004 | 04:46 PM
DCrosby's Avatar
No it's not Turbo'd
He's trying to remove the brake rotor first after that yes he'll have to remove that big nut, but first things first....
Old Feb 3, 2004 | 04:47 PM
Ozone Depleter
...it looks like that big nut holds on the brake rotor and you should only use the bolt hole to pry it off if its been rusted on...at least thats the way i read it.
Old Feb 3, 2004 | 05:05 PM
the big bolt is for the axle, seriously, you guys are making this harder than it really is. If you wanna remove the rotor(which I really dont believe you have to) take a rubber mallet and tap on the back of the rotor. That thing should pop right off. If you dont want to, take a hammer and beat that damn stud out. thats how I removed mine.
Old Feb 3, 2004 | 05:15 PM
DCrosby's Avatar
No it's not Turbo'd
With all that rust it won't pop free plus we're not talking about the nut in the middle, please look at the picture...
Old Feb 3, 2004 | 05:26 PM
gdnimr0d's Avatar
ok i got the rotor off with the screw thing you told me to do...now i cant get the stud out i mean i beat the stud out and its out and loose now but it doesnt have enough room to fully pull itself out from the axle so what do i do now?
Old Feb 3, 2004 | 05:28 PM
rfreeman27's Avatar
Lots of crappy info in this thread.
Dcrosby is right. Thread a bolt into that extra hole. As you tighen the bolt the rotor will come off. YOU DO NOT need to hit the rotor with a hammer! Bad idea!
As for the stud, you need to pull the hub off. You will take the huge nut off, then get a slide hammer and pull out the hub. Once its out, its simple to put a new stud in.
Old Feb 3, 2004 | 06:27 PM
gdnimr0d's Avatar
ok then so what size mm is the huge nut so i can go to sears and get the right size socket?? oh and what is a slide hammer?
Old Feb 3, 2004 | 07:16 PM
gdnimr0d's Avatar
doesnt anyone know???
Old Feb 3, 2004 | 07:24 PM
BigIslandSevens's Avatar
I use a 36 socket It works fine. A Slidehammer is a tool used to remove pressed on or clearence type fittings.( front hubs) However, all the ones I work on can be removed with just my hands. Give it a try. And use air impact to get that nut off it will save you frustration.The36mm is a little sloppy on the nut.( Can i say sloppy on the nut? )Hope that helps
Old Feb 3, 2004 | 07:43 PM
gdnimr0d's Avatar
haha alright then i will hopefully find something less sloppy i dont use air guns because i dont have the money i use a 3 ft custom made wrench extension that i made myself out of an old stilt and it applies more torque than an air gun could ever apply....it works for everything too bad it doesnt fit in places other that 3 ft big haha
Old Feb 3, 2004 | 08:04 PM
alberto_mg's Avatar
I agree. All you have to do is search. I had this happen to me and I just responded to someone else's post about this 2 weeks ago.
Thread a bolt into the hole as directed or use a crow bar like I recommended in another thread.
Oh and someone already had the same problem as you and post a nice write up on how to fix it. Search in the suspension/brakes section.
Old Feb 3, 2004 | 08:15 PM
Sesshoumaru's Avatar
Tenseiga
I dont' think the rotor needs to come off.
The bolt is on the spindal and should be able to just pound it out (put a nut on it first).
i broke 2 of them at once on a 240sx. Thought i was going to have to replace the whole spindal but only cost like 6 bucks and an hour (most of the time try'n to figure out how to fix it).
they are held in by the lug nuts so arn't threaded........
Old Feb 3, 2004 | 09:04 PM
Ozone Depleter
here is a pic of the replacement stud i got from autozone...why does the hub have to be removed for something that will simply slide out the back?
Old Feb 3, 2004 | 10:05 PM
rfreeman27's Avatar
Because the brake sheild gets in the way.
