Primary injector leak!!!!!!
Old Jun 25, 2003 | 06:37 AM
JSpecRZ's Avatar
NA2 Pilot
Replaced:
big top o ring
small bottom o ring
rubber seat
air bleed sockets
I coated them with oil and reinstalled them... and now the primaries are still leaking... I can smell it and see a little bit of fuel on top of the injector holder...
what else could it be?? the injector itself??
Old Jun 25, 2003 | 07:55 AM
pomanferrari's Avatar
Yes. At 64K, I had leaks from primaries and secondaries. Tried new o-rings, still leaked. Tried thicker o-ring, tried hylomar seal. Nothing worked.
Turns out the injector body becomes heat damaged and the interface between the metal body and the plastic housing deteriorates. The only fix is to get new injectors. They're not cheap at $200 each.
Old Jun 26, 2003 | 12:19 AM
rx7will's Avatar
Or you can get them rebuilt by rc engineering
Old Jun 26, 2003 | 03:51 AM
apeiron
rc engineering cannot rebuild injectors that are externally leaking... which, sounds to be your case.
I recently sent my injectors of to them as well to have them rebuilt. All but one were okay and they cleaned to run close to 100%. One of them was exteranlly leaking and they cant do anything about it.
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ZacMan
Sep 19, 2015 09:20 PM
gabescanlon
Sep 5, 2015 12:04 AM
FührerTüner
Sep 4, 2015 01:41 PM
