Microtech LT-10s - How to select adjustment points
Old May 16, 2012 | 10:50 AM
ChrisRX8PR's Avatar
Hello guys,
I have a microtech LT-10 and the map I am using is configured to adjust the load and idle/aux maps in intervals reaching up to 20psi. I know that the internal MAP sensor is good to 25psi and I would like to play with/change the adjustment points so that I can adjust up to 25 psi.
Any ideas as to where this is done?
Thanks in advance!
Chris
Old May 16, 2012 | 11:26 AM
flaco's Avatar
you mean to tune matrix ???
Old May 16, 2012 | 01:08 PM
ChrisRX8PR's Avatar
No, I mean to change what points I can adjust at based on inHG/PSI...
Right now on the LOAD and Idle/AUX maps I can adjust fuel at 30, 25, 20, 15, 10, 05, 00, 02, 04, 08, 10, 12, 14, 16, 18, 20
I would like to space out the ones from 04-20 so that the last point is 25psi for example...right now I can only tune up to 20psi...
Is there a way to select which points/intervals I can tune at?
Thanks.
Chris
Old May 16, 2012 | 04:31 PM
elturbonitroso's Avatar
you cant changes the load points.
Old May 16, 2012 | 09:24 PM
bumpstart's Avatar
talking head
PS,, check again,, all the LT and LTX i know of actually lack a 12 psi map
you need the unit to be sent back to be re-configured for the 3 bar map sensor and this will change the spacing of the load plots larger to still have 15/16 cells
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
FD3S_wanted
Sep 22, 2015 06:18 PM
The1Sun
Sep 15, 2015 04:45 PM
