18x9.5 +38 and 18x10 +30 Rolled Fenders
Old May 15, 2012 | 04:27 PM
WcKdUnAbel's Avatar
Veteran: Marine Corp
Ok so I have 18x9.5 +38 front and 18x10+30 rear with the fenders rolled not pulled. 9k Fortune Auto coilovers front and 7k for the rear. My question what is the largest set of tires I can put on the car... Ive done alot of research but its still foggy on what will work with rolled fenders and aftermarket suspension. This is a 93 Rx7
Old May 15, 2012 | 05:14 PM
FD2Envy's Avatar
I'd go with either 255(or)265/35 in the front and 275(or)85/35 in the rear.
Old May 15, 2012 | 06:05 PM
WcKdUnAbel's Avatar
i was thinking that too but i dont know if they will rub or how they will act... :/
Old May 15, 2012 | 08:04 PM
FD2Envy's Avatar
the 255/275 combo won't rub with rolled fenders, even with that +30 rear offset. The /35 tire profile will keep things from getting too out of hand, and your speedo somewhat accurate.
pic from wheel fitment guide:
https://www.rx7club.com/showthread.p...5#post11061555
https://www.rx7club.com/showthread.p...5#post10882824
https://www.rx7club.com/showthread.p...5#post10653530
https://www.rx7club.com/showthread.p...5#post10643459
Old May 16, 2012 | 05:33 AM
WcKdUnAbel's Avatar
ok cool thanks.... you think a 265 35 will work for the front???
WcKdUnAbel's Avatar
That red car his its fenders pulled..... :/
Old May 16, 2012 | 05:36 AM
WcKdUnAbel's Avatar
alot of the cars have their fenders pulled not just rolled
Old May 16, 2012 | 10:11 AM
DriftDreamzSS's Avatar
you should be fine with 255/275 combo and maybe a bit of extra camber to be safe.
Old Jun 2, 2012 | 04:46 PM
lOOkatme's Avatar
I have 265/35/18 18x9.5" with +45MM offset, rolled fenders and it fits ok.....not sure if you would fit with a +38MM offset. I think thats pushing it.
I would run a 255/35/18 front tire (its smaller OD as well), and a 265/35/18 rear tire.
