Microtech Timing differences between FCs and FDs
Old May 9, 2012 | 01:55 PM
BluRR's Avatar
Is there a timing difference between the FC and FD, such as a base timing difference. I ask because I am using a microtech LT-8X that as far as I know was supposed to be programmed for a FC on my FD (with FD ignition, crack, etc setup). I think i read somewhere on the forum that that there is a 5 degree difference between the crank reading between the FC and FD.
The question is do i need to make any adjustments to my microtech settings to compensate for this difference if there is actually one. So that I am not reading the timing incorrectly and making it too advanced or retarded and melt my motor?
Old May 10, 2012 | 10:04 AM
BluRR's Avatar
Anyone?
Old May 14, 2012 | 09:09 AM
BluRR's Avatar
Nobody knows???
Old May 15, 2012 | 04:59 AM
bumpstart's Avatar
talking head
FD only has a -20 ( 20 ATDC ) mark ( trailing )
FC has a -5 and a -20 mark
you have to set the L/T split to 15 degrees and use timing light on T1 and line that with the FD mark to be sure leading is -5
Old Jun 27, 2012 | 10:19 AM
BluRR's Avatar
Have you ever run a FC programmed ECU on FD? Is it safe?
Old Jul 11, 2012 | 09:17 AM
BluRR's Avatar
Anybody?
Does the FC and FD setup have different number of teeth on the crank that sensor pick up the rotation timing from?
Old Jul 12, 2012 | 08:49 AM
Aaron Cake's Avatar
Engine, Not Motor
FC and FD use the same trigger settings.
Old Jul 12, 2012 | 09:10 AM
BluRR's Avatar
So if i get my FD with original FD crank sensor started using a FC programmed ECU i should be fine? All is well? Just proceed like normally?
Old Jul 12, 2012 | 10:20 AM
rxspeed7's Avatar
F-IT
Yes
Old Jul 12, 2012 | 03:35 PM
BluRR's Avatar
thanks alot
Old Jul 12, 2012 | 05:38 PM
flaco's Avatar
Originally Posted by BluRR
thanks alot
unless the ecu was setup specially for fc or fd . not using the x4 .
Old Jul 12, 2012 | 10:42 PM
rxspeed7's Avatar
F-IT
Im almost positive but even if it was setup for the x4, as long as you use a "smart" coil that receives a 5v TTL signal it'll still work.
Old Jul 13, 2012 | 03:39 PM
BluRR's Avatar
its an Lt8x that used run an FC, not X4 box, but internal ignitors. Any problems there?
Queppa
Nov 18, 2024 03:47 AM
ppritchard
Interior / Exterior / Audio
Aug 21, 2015 06:02 PM
fastsaab
Aug 19, 2015 11:42 AM
