Exaust smoke-turbo or engine? How can I tell?
Old Jul 25, 2002 | 10:46 PM
boostmotorsport's Avatar
My T2 smokes at idle sometimes. It goes away for a couple minutes if I turn it off then back on. It does it a few times a week, but is becoming more often. The motor is a 1 yr old J spec, but the turbo has an unknown history, and whines a bit more than others I have had. Also there is some shaft play in it but not a ton. ITs blue smoke and smells of oil. Its not losing enough to noticably mower the oil level but is annoying/embarising. How can I figure out where its coming from? Also I run 10W30 in it, should I run something else?
Thanx
Old Jul 26, 2002 | 01:13 AM
Cameljoe's Avatar
Take the intercooler off and see if signs of oil coming from the turbo. You can go to a thicker oil and see if smokes less.
Old Jul 26, 2002 | 03:53 AM
Funklord's Avatar
run 20W50 castrol GTX. probbly wont fix your problem, but thats the oil 90% of FC owners use and swear by.
Old Jul 26, 2002 | 06:36 AM
There is some oil in the IC piping, but I dont know how to guage how much is too much.
Old Jul 26, 2002 | 07:41 AM
Josepi's Avatar
Despise Enmity
Smoke under WOT full boost-Turbo
If you rev it in N to 6-7K and hold it there for about 15 seconds then let off the throttle does it smoke?
A slight film is acceptable in the IC....
Old Jul 26, 2002 | 09:51 AM
It doesnt seem to smoke at WOT, but at WOT I am going fast enough to not see it!
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
