Megasquirt Fc with MS3 trouble wiring coils and cas
Old May 1, 2012 | 11:28 AM
88jdmfc's Avatar
VA Fc with MS3 trouble wiring coils and cas
I have an 88 jspec Tll motor and I'm wiring in the megasquirt ms3 into it and I've been resorting to aaron cakes site which has been a lot of help for me but I've only been confused on a couple of things and that's wiring in the CAS and also exactly which wires on the leading and trailing coils i have to wire in I've been looking at pictures and reading and I still can figure it out any help would be appreciated...thanks
Old May 1, 2012 | 01:47 PM
muythaibxr's Avatar
MegaSquirt Mod
On the CAS, the Ne+ wire should go to the mainboard tacho in pin, the NE- should go to sensor ground on the mainboard, The G+ wire should go to the ms3x's cam input, and the G- wire should go to sensor ground.
The spark outputs are:
Spark A: leading IGt
Spark B: Trailing IGt
Spark C: Trailing coil select.
Old May 3, 2012 | 08:10 AM
88jdmfc's Avatar
thanx just what i needed ill let u know if I have any more questions thanks alot
Old May 4, 2012 | 09:48 AM
88jdmfc's Avatar
im sorry which pin number are mainboard tacho the sensor ground on mainboard the cam input and the other sensor ground going to G-??
Old May 4, 2012 | 01:20 PM
muythaibxr's Avatar
MegaSquirt Mod
Please see:
http://www.msextra.com/doc/index.html#ms3
and more specifically:
http://www.msextra.com/doc/ms3/hardware.html#wiring
Ken
Old May 4, 2012 | 01:30 PM
88jdmfc's Avatar
ohh ok thnx perfect sry electrical is not my strong point
Old May 17, 2012 | 10:31 AM
88jdmfc's Avatar
sry for some reason i thought i had the ms3 but i opened up the casing and saw i ordered the ms2 v3.57 and was wondering if i had to mod the ecu to run the stock cas??
Old May 17, 2012 | 01:37 PM
muythaibxr's Avatar
MegaSquirt Mod
With MS2 to run the stock CAS you need to follow Aaron Cake's howto instructions. Basically you need a second trigger circuit to condition the signal from the second VR sensor in the CAS.
Ken
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
