Need help with FPR setting...
Old Apr 22, 2012 | 07:59 PM
3xBlack Vert-top Mike's Avatar
Mike
Ill start with my setup...I am currently running 720 injectors (primary/secondary) with a Walbro 255 fuel pump and adjustable fuel pressure reg. The motor is extended street ported with a stock turbo on 12-15 psi of boost exhaust etc.
My question is what to set my fuel pressure at? And I read something about having to disconnect the vac when I set it so what PSI should it read with the vac disconnected and what PSI should I see when its connected. Thanks for the help in advance!
Old Apr 23, 2012 | 06:45 AM
Mike
bump...can some please lend a hand? thanks...
Old Apr 23, 2012 | 09:27 PM
Mike
so out of 100+ members to view this no one can give me the PSI? lol ok thanks anyway guys...
Old Apr 25, 2012 | 10:13 AM
spazzytroy's Avatar
20b Tinkerer
What was it at previously? If you set it different than what the car was previously tuned on, you'll see richer/leaner AFRs across the board.
If this is the first tune, you have some wiggle room here so it's hard to give an exact answer. Stock FC pressure at idle is ~30psi as I recall. Fuel injector flow ratings are generally given at 43.5psi.
EDIT:
At idle, the fuel pressure should be about 28.4 psi. When the FPR is vented to the atmosphere, the fuel pressure should be between 34.1 and 34.9 psi. With engine off, ignition key to the on position, and yellow connector jumped, the fuel pressure should be between 64.0 and 85.3 psi.
http://mazdarx7.iougs.com/fuel.shtml
Old Apr 25, 2012 | 10:25 AM
bumpstart's Avatar
talking head
universal standard is to start at 43.5 psi ( 3 bar ) with no vacuum applied to the reg
depending on the porting and idle speed , the vacuum will change and thus can sometimes be almost 10 psi ( 20 inches Hg ) less during idle ( with vac on the reg )
Old Apr 27, 2012 | 06:22 AM
Mike
EDIT:
This is my first tune. Im running a Rtek 1.8 (standalone). Im really not positive what it i set to now because the previous owner was the one that set it. I was wanting to know what to set it at now since im pulling my FD FP out and putting in a Walbro 255 (using the same 720cc injectors). Also wondering if the pump would make a significant difference in pressure and if it would even need to be adjusted after the change...? Thank you very much for your reply by the way!
Ok thanks for the info! I really appreciate your help!
Old Apr 27, 2012 | 09:27 AM
spazzytroy's Avatar
20b Tinkerer
Originally Posted by 3xBlack Vert-top Mike
[...]and if it would even need to be adjusted after the change...?
Shouldn't unless you're putting in a pump that will flow more fuel than your return lines can handle (you're not). You should check it and set it anyways.
Also check out this link. You can skip all of the stuff that is Megasquirt related, but there is good general EFI related information in there.
http://www.msextra.com/doc/ms3/fuel.html
Old Apr 27, 2012 | 12:03 PM
Mike
Thanks for that link!! alot of info on there! Im putting the 255 to ensure efficiency as well as support up coming mods (bigger turbo etc.)...
eplusz
15
Oct 7, 2015 04:04 PM
rattlehead
Sep 25, 2015 10:55 PM
ZacMan
Sep 19, 2015 09:20 PM
