what size tire on 18x10 rims
Old Jul 25, 2002 | 01:24 PM
loi's Avatar
loi
my rims are 18x8 in front and 18x10 rear. can i fit 295 in the rear or 285 is the widest i can fit on a 10 inch wheel?
Old Jul 25, 2002 | 01:30 PM
ARD T2's Avatar
285/30 is the widest you should go. I would suggest a 245/35 for the front even though it's not reccommended on an 8" wheel all the time.
I'd really suggest going 235/40 and 275/35 for the setup you have.
Rishie
Old Jul 25, 2002 | 03:13 PM
loi's Avatar
loi
275 is not too small for a 10" wide rim? how about 245,40 18 front and 285,35,18 rear? do i need to roll my fender on the rear?
Old Jul 25, 2002 | 03:18 PM
ptrhahn's Avatar
Most tire spec sheets say 9-11" for a 275. Tires work better on a rim that is toward the wide side of their range. 285/35/18 might be a little too tall. 275/35 oughta be just about perfect.
Old Jul 26, 2002 | 09:44 AM
SleepR1's Avatar
Actually 275/35-18 is also too tall.
295/30-18 is really the best match with regard to overall tire diameter...it's ~25 inches. You will need a 10.5 or 11-inch wide wheel for a 295/30-18...That's the size I'd get in back...
Up front I'd do 255/35-18 tire size which is also 25 inches in overall tire diameter. I'd use a 9.5-inch wide rim for the 255/35-18 tire for maximum sidewall support.
Old Jul 26, 2002 | 01:15 PM
ARD T2's Avatar
The problem with that Manny are his wheel widths. Would you reccommend him putting the sizes you've mentioned on those wheels? I doubt you would so I think we go back to my closest to the best thing and that's a
235/40 and 275/35 or 265/35 to math O.D. w/235. I understand the 275 is too tall but what can you do.
I run 265/35 on my 18,10's for my bimmer. Check it out. I think they look incredibly phat.
http://groups.msn.com/AutomotiveRD/a...to&PhotoID=432
**** I didn't have a good picture loaded up. I'll have to add it and then link later. Sorry.
Old Jul 26, 2002 | 10:56 PM
SleepR1's Avatar
Ahhh...I didn't see that he has 8s and 10s to work with...in that case I agree 100% with your tire sizing...235/40-18 on 8 x 18 and 265/35-18 on 10 x 18...tire overall diameters are just about the same at 25.4 and 25.3 fr/rr, respectively...sorry for not reading closely, Rishie
Old Jul 27, 2002 | 12:48 PM
ARD T2's Avatar
No apologies necessary here. WE're all here to help for the greater good. hehe. I have yet to find a time where our advice is not in synch.
Laters.
Old Jul 30, 2002 | 11:49 AM
loi's Avatar
loi
Thanks guys, i ordered the tires yesterday
Old Aug 5, 2002 | 07:40 PM
loi's Avatar
loi
i ended up going with 245,40 ,18 in front and 275,35,18 rear. i will get it mount and balance tomorrow.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
