Microtech ignition problem question
Old Apr 21, 2012 | 03:41 PM
eddierotary's Avatar
back with rotaries
I know is not rotary related but a friend of mine's 2jz vvti swaped 89 supra is having problem with his lt16. Is reading higher rpm that what the motor is turning. Like the ecu is reading 3khigher when the engine is only turning 800. We swapped the crank sensot and didnt fix the problem. Check all the wires and still the same. Can anybody help please. Thanks
Eddie
Old Apr 21, 2012 | 05:15 PM
flaco's Avatar
u sure is the MT ?? or maybe is the cluster??
Old Apr 21, 2012 | 05:50 PM
RotaryEvolution's Avatar
Sharp Claws
the ignition setup is incorrect then, be sure it is set for a 6 cylinder and not a 4 banger or 2 rotor.
Old Apr 22, 2012 | 07:34 AM
back with rotaries
The computer is set for 6 cilinders. All i can think is that the ecu is not setup right at microtech because i called around to check if the sensors are different thru out the years and they are not . I rev it up a lil and the ecu reads like 6-7k the when i know is not that high.
Old Apr 22, 2012 | 11:33 AM
Sharp Claws
is this reading coming from the tach or the ECU itself?
Old Apr 22, 2012 | 12:00 PM
flaco's Avatar
is it reading that high ?? or is it glitching ??? what about the crank sensor cable ?? did you modified cut it and splice it ??
Old Apr 28, 2012 | 05:49 AM
Arecibo's Avatar
How about checking the rpm with a known good gage
( meter)
alphawolff
Nov 17, 2015 05:57 PM
Joe428
16
Aug 19, 2015 06:24 PM
gtcd
30
Aug 19, 2015 02:44 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
