Ron New Member
Old Apr 18, 2012 | 03:16 PM
alchemist_ron@yahoo.com's Avatar
FL Ron New Member
When posting any thread concerning the need for help pertaining to any diagnostic help, there are minimum guidelines for us to help you.
1st). I just bought a 87 RX-7 w 1.3 non turbo . Has Bridgeport intake
2nd).Yup Bought a Haynes manual. Very terse.
3rd). Car was in pieces when I bought it. Fuel pump resistor was cut out of wiring. Got all wires connected except a couple running out of Passenger side firewall. no idea where the Oxygen sensor connects.
4th). !st problem I had was bad wire inside gas tank. fuel pump is good.
5th). When I first put the engine together and primed it w gas. i got a rev so ignition did work. Did not see the primary injectors on first round so in the course of plugging them in i bumped the intake against the alternator . got sparks. Think I blew the ECU . Ordered another one.
No blown fuses or burnt wires so must have found unprotected path back to ECU. Waiting for another one right now.
Old Apr 19, 2012 | 03:07 AM
Furb's Avatar
Rotary and Engineering
Why do you think the ecu is blown?
Old Apr 19, 2012 | 01:14 PM
FL Ron New member
My son and I checked and there is no ignition when before I removed the intake there was ignition. Checked the self check got nothing at all.
Old Apr 19, 2012 | 03:56 PM
SirCygnus's Avatar
whats going on?
air flow meter
Old Apr 20, 2012 | 06:15 PM
Air Flow meter. I don't understand how a bad air flow meter could produce zero spark?????
Old Apr 21, 2012 | 08:50 PM
Replaced the ECU. Now it runs. Did not know the ECU was that easy to blow. Burned via the TPS wires.
likestodrive
Sep 15, 2015 06:30 PM
