Power FC Full Bridgeport Ignition Timing on boost power fc
Old Apr 11, 2012 | 05:29 AM
postert's Avatar
Hi,
Can anyone help ignition timing on boost?
Now my IGL timing is:
10psi=13 deg
13psi=11 deg
16psi=9 deg
19psi=9 deg
22psi=? deg
Split abaut 15deg
Is this timing safe?
Some specs:
rx7 fd3s
13b turbonetics t66 water/meth injection 50/50
Injectors 850/1680cc fuelpump bosc044
apexi power fc
4"downpipe 3,5" exhaust
Full Bridgeport
hks twin power
9l and 10.5t plugs
Regards,
-Postert
Old Apr 11, 2012 | 10:47 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
others may have better numbers for you but certainly your 9 igl w a 15 split is conservative. i would run 11 split and have no worries. the Power FC adds one degree around 4000 and another shortly thereafter so i assume the numbers you supply are off the base ignition map and you will have another 2 degrees, which is actual, logged at higher rpms.
one item i do not like is 9 heat range in the lead. w your setup you should have nothing warmer than 10 and 10.5 would be better if your ignition will fire it...
good luck,
howard
Old Apr 11, 2012 | 01:34 PM
postert's Avatar
good luck,
howard
Thank you very much,
I change my all plugs NGK RACING SPARK PLUG R6725-105 what you think those plugs?
next week i go dyno, then i can try 11deg split.
same 9 igl is between 4000-8000rpm
can i try same 9igl and 11 split bigger boost, abaut 22-24psi if my injectors allow that?
Best regards,
Postert
Old Apr 13, 2012 | 03:57 PM
cewrx7r1's Avatar
Eye In The Sky
Go to http://bdc.cyberosity.com/main.php and download his zipped maps.
indispeed's Avatar
what type fuel ??
Old Apr 14, 2012 | 01:15 AM
postert's Avatar
Originally Posted by indispeed
what type fuel ??
Fuel 98 octane.
Old Apr 14, 2012 | 01:38 AM
postert's Avatar
Thank you.
I look those maps and timing on boost is some, 2-4deg later.
befarrer
Microtech
Aug 22, 2015 05:52 PM
Turblown
Aug 14, 2015 04:48 PM
