Borg Warner 380
Old Apr 9, 2012 | 09:56 AM
1NSIGHT's Avatar
I Used to Park Cars
Borg Warner 380
Ok i know this turbo is over kill, like no other but I found one at an extremely low price. How bad would the lag be on it?
How big of wastegates would I need to run it? Im sure ill probably need two.
Edit: I only plan to make 400hp on my car.
Old Apr 9, 2012 | 08:45 PM
1NSIGHT's Avatar
I Used to Park Cars
Specs: 80mm compressor wheel
5.5 mm inlet with 3.5" discharge
83mm exhaust wheel
1.00 a/r exhaust housing with 4" discharge
Old Apr 9, 2012 | 10:38 PM
Cosmo_TT's Avatar
BRAAAAAP pssh BRAAAAAP
how good of a deal? you can get an s360 for 650-799 and itll make your 400whp much much better
Old Apr 10, 2012 | 09:05 AM
1NSIGHT's Avatar
I Used to Park Cars
900 dollars. Im really just throwing the idea out there. I know what turbo im going to get but I found this so I decided to ask.
Old Apr 12, 2012 | 05:43 PM
ScorpionT's Avatar
First, the 80mm compressor is a bit large for the 83mm turbine wheel when paired with a rotary. If you arent pusing the turbo hard that wont be an issue.
Second, the turbo is much too big for your power goals. You will have unnecessary lag and it will make the car less fun to drive. For $900 you can find a smaller turbo that will better match your power.
Old Apr 12, 2012 | 06:28 PM
flaco's Avatar
go with the s366 is cheaper
Old Apr 12, 2012 | 07:40 PM
indio84's Avatar
Try it. low booat you will have your 400.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
eplusz
15
Oct 7, 2015 04:04 PM
