Power FC Swapping 1200 for 1680 secondaries; any simple PFC updates to keep the car drivable?
Old Apr 8, 2012 | 01:24 PM
moehler's Avatar
I will be swapping out my secondary injectors and upgrading to 1680's with a full kit (kg parts/rx7store kit). I would like to keep the car drivable to at least make the two hour trip to get tuned. I don't have a datalogit; is there anything simple I can do from the commander to maintain drivability? Will the car drive ok without any PFC updates?
Thanks.
Old Apr 9, 2012 | 06:53 AM
socks's Avatar
You only have to calculate duty cycles for the primary injectors.
So all you have to do is adjust the injector size under "Setting ---> Injector", and account for any difference in injector lag.
The stock secondaries have a lag time of .77ms, so if your new injectors have a lag time of .85, you would change them both (Fr-Sc, and Rr-Sc) to +0.08ms
Your new injectors should come with a spec sheet.
Feel free to read page 26 here:
http://www.clubrx.org/media/pfc/PowerFC_FD3S.pdf
Old Apr 9, 2012 | 10:10 PM
cewrx7r1's Avatar
Eye In The Sky
Changing the secondaries will not affect idle, cruise, or light acceleration.
Old Apr 10, 2012 | 10:09 AM
moehler's Avatar
^Thanks guys. Yeah, I was hoping if the car didn't drive very well I could tweak a few commander settings to make it more drivable. Hopefully it wont be bad at all... but I've never jumped to 1680's without a re-tune before so I'm not 100% sure.
Old Apr 10, 2012 | 11:36 AM
thewird's Avatar
Your going to be able to drive it the same. Secondaries only come on under boost and at higher rpm, the injector difference isn't even that big either. I wouldn't even bother changing anything in the tune except change your lag to +0.16 (that's what I use). Until you. At least.
thewird
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
torky007
Aug 17, 2015 05:14 PM
Snook
Aug 15, 2015 08:18 AM
