Millenia S 17's on an FC hub? spacer issue
Old Mar 21, 2012 | 02:10 PM
lucky87T2's Avatar
Question Millenia S 17's on an FC hub? spacer issue
Ok guys so I picked up a set of factory millenia S wheels , this style- http://media.ed.edmunds-media.com/pi...44-300x189.jpg17x7 with a 67.1mm hub bore, similar to the FD wheels. I am looking to run a 25mm spacer on all four corners to get these to fit nicely. Here is the problem I'm having....
I am wanting to buy these spacers -
http://www.ebay.com/itm/SILVER-BILLE...ht_1161wt_1396
How are you supposed to use these when the holes for the factory lugs are not drilled through? I cant understand how they would secure to the factory hub..... most other spacers have the holes drilled through so you can bolt the factory lugs on therefore securing the spacer to the hub, and then the wheel bolts to the spacer....
these are the only decent priced spacer that fits the FC so im really set on these if they work somehow?
what am I missing here??
thanks in advance!!
Old Mar 21, 2012 | 05:13 PM
BLACK MAMBA's Avatar
FD Project
i think the picture isnt showing them drilled, but the description say that they bolt in top of the rotor hub, i sugest that you contact seller by ebay and ask him about the holes.
Old Mar 21, 2012 | 06:49 PM
lucky87T2's Avatar
Okay well I guess im not crazy then for thinking his image is an unfinshed product, seems dumb to post a picture like that but oh well I guess.... I emailed the seller and I'm still waiting for a response.
thank you for the reply!
rgordon1979
40
Mar 15, 2022 12:04 PM
Clacor
Sep 11, 2015 08:36 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
