New Intake
Old Jul 24, 2002 | 04:08 AM
spedrac22's Avatar
New Intake
I want to get an Intakefor my car. I will also get that Fuel Cut off program from racing beat also. Do you guys think it would be a good idea. I have a stock 88 turbo II. just replaced belts and got braided oil lines. I also wanted to know if it would be a good idea to take the smog pump off. thanks for relies
Old Jul 24, 2002 | 06:01 AM
jspecracer7's Avatar
1JZ powered
Re: New Intake
Fuel cut off program? Sounds funny like that. I've always seen it as a Fuel Cut Defenser. Just fools the stock ecu into thinking less boost when there's more. Intake good idea. FCD only when you're going to be running more boost. With just the intake, you shouldn't get higher boost. With a full exhaust AND intake, you will definitely get boost cut, so you'll need an FCD. With the smog pump, keep it until you get a full exhaust. No smog pump AND catalytic converter = clogged cats....something you may have anyways
