Engine Throbs
Old Jul 24, 2002 | 02:27 AM
ChrisM's Avatar
Newbie
Unhappy Engine Throbs
Hey Guys
New to forum, just put my 7 on the road and it's been great so far. However earlier today a NEW problem has developed. The engine seems to throb (like I was tapping the throttle) not only does it do this at idle but even when I give a little gas it just throbs faster. It seems to be driving fine has plenty of power but very annoying at stop lights. If it's any help I have a K&N cone intake and a custom catback exhaust (single pipe )
Thanks in advance
Old Jul 24, 2002 | 02:39 AM
BoostedRotors's Avatar
I HATE sleepy eyes
Sounds like you got yourself a vacuum leak! fiddle around under the hood and see if you cant find it...if not there are ways...spraying carb cleaner, soapy water, etc. If its messing up your idle Id assume that if you stuck your head under the hood you could hear it, should be a decent sized leak.
Old Jul 24, 2002 | 04:21 AM
Funklord's Avatar
thats a TPS problem. my car did the same thing when i screwed with my TPS. a vacuum leak would be a rough unsteady idle like robbrrrpoopopoopouhhuubbbbpopoprrrbubub, but this problem is more like ruhbooruhbooruhbooruhbooruhboo like someone was flooring it, the letting off, the flooring it then letting off etc. i adjusted mine and it got a lot better but still does it sometimes when my car is warming up. so adjust your TPS. i've heard the ohms method is the best way, but for me the volts method gave me better results.
Old Jul 24, 2002 | 04:22 AM
Funklord's Avatar
but for the time being if someone asks you about your weird idle, say its your high performance cams.
Old Jul 24, 2002 | 08:43 AM
Suds's Avatar
Your sound effects are most accurate
I have the TPS problem
Should adjust, i have heard the ohms method is the best.
Old Jul 24, 2002 | 10:31 AM
blu_gxl's Avatar
yes, it's a tps problem it's due to the air filter and exhaust change. the ohm meter method is more accurate but, i have found the two light method is much easier and not much less accurate. adjust and you will be fine
Old Jul 24, 2002 | 11:13 AM
GLHS's Avatar
Shelby Tuner & FC badass
Try cleaning your AFM and the throttle body, use throttle body cleaner only and clean the inside out, it sounds like you have some crud in the AFM and is making it difficult to operate. Just seen this 2 days ago.
Take the AFM off the car and spray it out, make sure the door inside opens and closes easy and doesn't catch or move slowly.
When you are done cleaning, pull the plugs and pull the first fuse towards the engine on the drivers shock tower.
Hold the gas pedal to the floor and crank the car over for about 15 seconds, or once the mist stops coming from the open spark plug holes.
Put it back together and welcome the faster throttle response and no more problems.
Old Jul 24, 2002 | 09:26 PM
ChrisM's Avatar
Newbie
Ahh TPS
Hahaha
Your sound effects were spot on Funklord... if you sound it out thats exactly how it sounds... will tackle the TPS tommorow...
Thanks
Microtech
30
Apr 23, 2016 06:37 PM
Wicked93gs
Aug 23, 2015 10:14 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
