Sponsored by: CARiD
Whats More Efficient...tmic or fmic
Old Mar 15, 2012 | 02:50 AM
audoetuk's Avatar
Exclamation Whats More Efficient...tmic or fmic
Which is the better working choice between a front mount intercooler or top mount intercooler?
Old Mar 15, 2012 | 10:16 PM
n.taluckder's Avatar
tmic if your running stock turbo, fmic otherwise bth the jdm s5 is the most eficient of all stcok tmic's
Old Mar 16, 2012 | 12:57 PM
audoetuk's Avatar
I read tmic is better bc its shorter piping so less lag
Old Mar 17, 2012 | 12:55 AM
misterstyx69's Avatar
Retired Moderator, RIP
Ya but you can only run so much intercooler on top of the engine.
You can put a massive intercooler out front or run a Vmount that would be more efficient than the top mount..Also with the Different turbos out there Lag is not really a problem.
Old Mar 17, 2012 | 04:38 PM
audoetuk's Avatar
Yea I mean vmount
Old Mar 18, 2012 | 01:33 AM
carboy's Avatar
I too am looking to do a V-Mount. What is a good V-mount kit? Has anyone done the Greddy one? The new HKS one looks massive. But the prices are a bit high on those kits. I figured that the V-mounts are good for cars that are in hot areas like Texas.
Old Mar 18, 2012 | 02:25 AM
audoetuk's Avatar
Rotary-works.com has a good one
Old Mar 22, 2012 | 05:17 PM
HahaManLaw's Avatar
I'd go fmic and take the better cooling than the top mount that's sitting right on top of the engine.
Old Mar 27, 2012 | 10:04 PM
anees's Avatar
amemiya7
again alll these intercoolers are good for diff setup
smic is good for daily and minor tracking here and there
v mount.. serious track stuff
fmic.. if u drag ur car and want to push big numbers
Old Mar 27, 2012 | 11:34 PM
audoetuk's Avatar
O aiight, then vmic should be more than good for street/track
Old Mar 28, 2012 | 12:16 AM
tasty danish's Avatar
Doesn't suck
This thread is really elementary/misinformed. This is all also covered extensively elsewhere.
Bottom line: V-mount if engineered properly is the most effective solution. the problem is this involves a significant amount of engineering/ducting/routing to get the air flow to the radiator and intercooler correct.
FMIC: simple and effective. Cons: decreased effectiveness of radiator and longer tubing
TMIC: crap. Heatsoak FTL. Stock piping is inefficient.
Old Mar 28, 2012 | 12:56 AM
audoetuk's Avatar
Well I don't know if you have the same experience using the search here, i get threads that gave my topics words a good one time & don't really have what I look for so I jus ask my own questions...good info
Old Mar 30, 2012 | 03:35 PM
camman's Avatar
water to air, given you properly size your heat exchanger.
Old Mar 30, 2012 | 06:17 PM
Doesn't suck
Between this site, google, and miataturbo.net I have taught myself almost everything there is to know about being a car enthusiast. What are you searching for? You want to find just general intercooler theory talk.
I promise you the guide lines I laid out are GENERALLY spot on.
Old Apr 11, 2012 | 01:31 AM
automationLED's Avatar
would a vented hood on a stock TMIC be beneficial?
Old Apr 11, 2012 | 06:24 PM
Doesn't suck
Properly placed, vents are always helpful. How are you going to get airflow through the IC if it is directly on top of engine? Isn't that why the turbos have a scoop?
Old Apr 13, 2012 | 11:54 AM
RotaryRocket88's Avatar
Top Down, Boost Up
TMIC + water/meth injection or no intercooler + lots of water/meth injection are options too.
