Power FC Easy way to test for required upgrading of fuel pump wiring?
Old Mar 10, 2012 | 12:13 PM
rotarypower101's Avatar
sdrawkcab
What would be a good way to test and see how a fuel pump is loading a system and make a good judgment on whether the wiring should be upgraded regardless of the components and system.
Purely a look at the fuel pump and see if it operating in a specific way?
Is there a inexpensive voltage converter that could take ~ 0-15VDC and convert it to 0-5VDC so it could potentially be logged?
Or is it better to just indirectly look at fuel pressure?
Is there a way to bench test the loading characteristics ?
TIA
Old Mar 11, 2012 | 10:37 AM
ttmott's Avatar
Measure voltage simultaneously at the pump and at the fuse. There will be a voltage drop concurrent to the amperage demand. If you have more than one volt difference I would recommend upping the wire, connector, and relay sizes. V=IR
Old Mar 11, 2012 | 10:50 AM
tom94RX-7's Avatar
either way it's a good idea to do the rewire if you want max performance from any pump, a test is not needed, it will be better than stock.
I have a autometer electronic fuel pressure gauge, there is a sender that screws into the aeromotive fpr and wires go to the gauge in the car, and the purple wire is a 5v output that you can connect to datalogit to datalog fuel pressure
Queppa
Nov 18, 2024 03:47 AM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
