ABS sensor Test Points?
Old Feb 21, 2012 | 01:13 PM
ppritchard's Avatar
93 Touring
FL ABS sensor Test Points?
The FSM shows testing each ABS sensor at it's connection, 2 under the hood and 2 under the bins. Then later it shows testing all 4 at the ABS cpu in the rear hatch area.
Can you test at the cpu and Not have to get under the bins? Or are you testing something different by testing the pins there vs the connectors?
The under hood ones are easy, hate to keep taking the bins out as each time is another chance for plastic breaks.
Thanks for any insight
Old Feb 21, 2012 | 04:43 PM
DaleClark's Avatar
RX-7 Bad Ass
What's wrong with your sensors/ABS? The ABS system is pretty darn hardy.
It's just wires from the sensors to the ABS computer, you can easily test continuity on those wires if you have a long enough lead on your multimeter.
Most common problem I've heard of is broken/torn wiring by the sensor from road debris, a wreck, or pulling on it while working on the car.
Dale
Old Feb 21, 2012 | 05:14 PM
ppritchard's Avatar
93 Touring
We have an ABS light that's been solid on forever.
Need to see if it's one of the sensors or the cpu
Trying to figure out if testing at the CPU will give the same info
as testing under the bins.
Old Feb 21, 2012 | 07:08 PM
DaleClark's Avatar
RX-7 Bad Ass
I would think so. I'd do a visual on all the sensors to start with. Next thing would be testing the relays in the ABS pump, which is outlined in the shop manual.
The computer itself is most likely OK, that's a hardy unit and out of the elements, I doubt that is going to be your issue.
Not sure if there's some other test procedure to get the light to flash a code or something. The shop manual just shows how to use the expensive Mazda tool to check things out.
BTW, I've been on a roll with your questions lately .
Dale
Old Feb 22, 2012 | 05:46 AM
ppritchard's Avatar
93 Touring
Dale,
Yes you have. Thanks for all the Experienced answers.
The flashing light option is not available on the '93, but is later -- wish I had that tool.
I'll check the pump relay today.
Old Feb 22, 2012 | 11:24 AM
Okie-RX7's Avatar
Test each sensor at their connectors, testing from the ABS cpu just checks for continuity through the wiring harness, not the resistance of the sensors. Also, check to make sure the ABS pump is getting power (FSM P-51), this is what was wrong with mine, my connector had a corroded pin. I would check those and see what you come up with, but, like Dale said it is a pretty robust system.
When does your ABS light come on, as soon as you start the car or when you start moving?
Old Feb 22, 2012 | 12:14 PM
ppritchard's Avatar
93 Touring
Thanks.
ABS light is on from the time you turn the key, never goes off.
It has been that way for a long time, just getting to it.
Old Feb 22, 2012 | 11:25 PM
Okie-RX7's Avatar
I would start with your relays and fuses, then check your sensors and wiring. If it was a wheel
speed sensor I would think that would throw the light when you start moving. If everything
checks out and you want to test another ABS cpu pm me, I have one laying around you can try.
Old Feb 23, 2012 | 06:50 PM
ppritchard's Avatar
93 Touring
Ended up replacing the Control Unit/Pump since it was leaking.
That also eliminated the ABS light, so good to go now.
Old Feb 24, 2012 | 06:00 AM
ppritchard's Avatar
93 Touring
Oh Well -- no ABS light for 50 miles, then it popped back on again.
Back to the drawing board
Old May 15, 2013 | 08:39 AM
MuRCieLaGo's Avatar
Forever blown!
For further readings of this thread, answer is at P-59 of FSM.
Skeese
65
Mar 28, 2017 03:30 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
efini7
Test Area 51
Sep 4, 2015 02:59 AM
