Should I buy this fc?
Old Feb 18, 2012 | 06:41 PM
kacex's Avatar
So I've been looking around a few months for an fc. I'm thinking about taking the plunge on a '90 red na that won't turn over, but I'd like some input before I can consider it seriously.
The owner explains that the car has been sitting for over 4 years. He stopped driving it because it needed a new clutch. And now that it has been replaced the car won't start, even with a new battery. They are asking for $1500.
My questions are:
1. Do you think the car is fixable?
2. What could the problem be?
3. Considering the state of the car what should I offer? (assume int/ext are in acceptable condition, I haven't received any clear pics of it yet)
4. Should I even bother checking it out in person?
Old Feb 18, 2012 | 11:36 PM
misterstyx69's Avatar
Retired Moderator, RIP
Pass it up.
..4 years sitting??.. not only are you looking at a new clutch,you would have to redo all the brakes,hoses,spark plugs and wires,fuel filter and sock( in tank ) and..the list goes on.
My guess for not starting is that the clutch is totally shot and the pedal is not hitting the Interlock switch( under the clutch pedal's arm)..you press that in and turn the key,it may wanna roll over.
Old Feb 19, 2012 | 05:11 AM
dwb87's Avatar
This is my social media.
I am going to have to agree with misterstyx69 on this one.
My questions are:
With money and a proper diagnosis, yes.
They may claim that the only problem is the clutch. That seems completely suspicious to me. A bad clutch is no reason to let a car sit for four years. Perhaps there is a blown coolant seal or something internally wrong with the engine. If this is the case... The engine will require a rebuild.
IF they are able to provide acceptable compression numbers on each rotor face, the body is straight with minimal rust and a decent to great interior... Then I'd say $700 at most. They'll probably laugh at you, but they won't be laughing when it is still sitting around six months later.
I'd pass on it. Eventually they'll realize they're asking far too much for that car.
Old Feb 19, 2012 | 09:44 AM
Marx-7's Avatar
rotary!!
If the car is not too far away from your home i would still be curious and check it out. Better to judge a car in person then by pictures.
for the rest i totally agree with dwb87
Old Feb 20, 2012 | 04:01 PM
kreativekvs209's Avatar
i would expect to buy a new motor. go there kick the tire, and over him $700. if he say no then walk away. i dont know about where you are but around here. you can find a decent 7 for $1500
Old Feb 21, 2012 | 06:10 PM
_KiD_'s Avatar
I'd wait for another one to come up...
Old Feb 22, 2012 | 10:16 AM
there's a automatic fc3s going for 800 found closed by stockton craigs.
Old Feb 22, 2012 | 06:23 PM
amiralawi's Avatar
1500 is hard to justify if it doesn't run. A (somewhat) low mileage FC that runs can be had for 3000 all day.
Old Feb 25, 2012 | 11:29 PM
flexxi's Avatar
next
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
Cameron38
1st Gen General Discussion
Sep 19, 2015 11:45 PM
mulcryant
Sep 9, 2015 05:24 PM
