S4 turbo transmission with s5 turbo flywheel. What series turbo clutch kit to use?
Old Feb 17, 2012 | 04:09 PM
MANSU_V36's Avatar
Im putting a s4 turbo transmission on to my s5 6port engine. Of course ill be using s5 turbo flywheel. My question is which series turbo clutch kit will i have to use, S4 turbo or s5 turbo?
Old Feb 17, 2012 | 04:27 PM
FirstRotaryExp's Avatar
The Brap is Back
S4 and S5 turbo clutch's are the same diameter so it matters not which you take, only thing that matters is that you pick a clutch for a the Turbo flywheel and not an NA.
Old Feb 17, 2012 | 04:44 PM
MANSU_V36's Avatar
I asked because mazdatrix has different Part numbers for s4 oem turbo clutch kit and s5 oem turbo clutch kit. Thanks alot
Old Feb 17, 2012 | 05:01 PM
misterstyx69's Avatar
Retired Moderator, RIP
Transmission doesn't have Squat to do with what you run as a Clutch.
It's the Engine.(and whether it is N/A or TII)
Old Feb 17, 2012 | 05:18 PM
The Brap is Back
Actually, the trans has as much to do with clutch selection as the flywheel. The clutch disc itself has to mate to the transmission input shaft (which NA and T2 have a different spline count). Of the same token, flywheel diameter also factors in clutch disk diameter and pressure plate diameter.
When I used to havea Starion/Conquest I used to keep up with their forum as well, and on it there was a guy that specialized in making bellhousing adapters for various engine swaps and transmission swaps. He would always state that when selecting a clutch you would buy for the transmission (coincidentally the 88/89 model year starion/conquests used the same diameter flywheel as the turbo rx7's)
But OP has stated hes using a S5 turbo flywheel (on a S5 NA) and mating the S4 turbo trans to it (which is all well and good as S4/S5 trannies are interchangeable, just the trans mounts differentiate).
So he needs a 13BT clutch set of either S4 or S5 origin, which series he chooses is probably up to the wallet if there is a pricing difference
Old Feb 17, 2012 | 06:21 PM
bumpstart's Avatar
talking head
s5 = 235 mm
s4 = 245mm
this is the reason for the part number changes
BOTH retrofit to either flyhweel, no consequence
Old Feb 17, 2012 | 10:44 PM
MANSU_V36's Avatar
Originally Posted by bumpstart
s5 = 235 mm
s4 = 245mm
thanks guys for making it clear.
Old Feb 17, 2012 | 11:04 PM
What am I thinkin??
sorry man,,I must have dozed off..damn winter hibernation!
Old Apr 18, 2012 | 11:02 PM
theshdwconspracy's Avatar
Trash Talk
are the starters different? Since the starter bolts to the transmission wouldn't it effect the engagement if you mix flywheel and transmission? i.e an s4 starter wouldn't reach an s5 flywheel because of the 10mm difference in diameter.
Old Apr 19, 2012 | 02:50 AM
Furb's Avatar
Rotary and Engineering
Flywheels are the same, its only a difference in clutch disc diameter
Old Apr 19, 2012 | 10:33 AM
Trash Talk
Anyone know the flywheel diameter?
Old Apr 19, 2012 | 11:10 AM
Furb's Avatar
first page in google..
Old Apr 19, 2012 | 12:12 PM
RotaryEvolution's Avatar
Sharp Claws
turbo starters are interchangeable as are the non turbo if you keep it either boosted or naturally aspirated being that the non turbo starters have the solenoid on the opposite side of the starter.
the non turbo automatic starters are the exception and can be used as a high torque alternative for turbo motors.
basically there is non problem using a s5 TII starter on a s4 TII and vice versa.
