Microtech 2x OEM 550cc 2x 1600cc LT10S Map
Old Feb 15, 2012 | 10:32 PM
88durel's Avatar
Shaolin7
Talking 2x OEM 550cc 2x 1600cc LT10S Map
Hello everyone,
I recently purchased a Microtech LT10S that was running a 12A Bridgeport w/ 550s and 1200s. I would like to clear/adjust the map and re-enter/adjust one that will work with 2x OEM 550cc and 2x 1600cc injectors on a race port 13b with a Turbonetics T4OE .60 AR . 84 hot side turbo.
Full Specs of setup:
S5 Internals
Fuel:
Bosch 040 Fuel Pump
1600cc Injectors x 2
550cc OEM Injectors x 2
Spark:
Bosch HEC 715 Coils x 4
Microtech X4 Ignition Module
ECU:
Microtech LT10S previously mapped for a 12A bridgeport with 2x 550cc and 2x 1200cc injectors.
Turbo:
Any Assistance would be much appreciated!
Old Feb 15, 2012 | 10:43 PM
rxspeed7's Avatar
F-IT
The map on there should work to get you started and to a tuner
Old Feb 16, 2012 | 09:32 PM
88durel's Avatar
Shaolin7
Thanks rxspeed7! Going to give it a try and see what happens
Old Feb 16, 2012 | 10:17 PM
bumpstart's Avatar
talking head
look at your current % stage value
subtract it from 99
use the result number as negative mix trim
shift the stage % from what ever it is up to 99
if you cant get your head around that math then-
just limp it out of boost ( it will be exceesively rich after staging ) to the shop
