another white smoke thread...
Old Feb 14, 2012 | 11:11 PM
cr-rex's Avatar
half ass 2 or whole ass 1
i have searched all the white smoke threads i could find. some of them were slightly relevant but not entirely. there was a general theme with them though... lets see if i get the same answer...
the issue is, i only get white smoke after flooring it through a couple gears, usually 1-3rd. i only did it twice since this problem, started. the first time i didnt know it would happen and the second time because i didnt think it was going to happen again.
it only blows white smoke for maybe 30seconds then stops. it will only happen when i take it to around 6k. the 2 times it happened.
my mod list is as follows:
hks 3in downpipe with 3 1/4in exhaust all the way back
stock twins
recently did the hose techniques vacuum line change
blitz smic
apexi intake with custom pipes
efini y pipe
air pump-less
alluminum radiator with silicone hoses
thats all i can think of that would be relevant. if there is something else anyone would need to know please ask. i can drive the car normally all day and no issues of any kind will arrise. but the 2 times i floored it and the smoke came i was worried so i have been taking easy until i can find a solution to this.
any help is appreciated...
Old Feb 15, 2012 | 12:59 AM
Reno_NVFD's Avatar
Dont know what to tell your about you specific problem but I can say that with your mods you should be running an aftermarket ECU and a tune. With your open exhaust and intake your probably boosting far above stock levels.
Does the smoke happen when you let off the gas after a hard run?
Last edited by Reno_NVFD; Feb 15, 2012 at 01:01 AM. Reason: I cant spell and my grammer sucks
Old Feb 15, 2012 | 01:23 PM
bufferovrflo's Avatar
I suggest placing a catch can of some sort running off your oil filler neck to the inlet on the turbo. I had similar issues and this solved it
Old Feb 15, 2012 | 11:03 PM
cr-rex's Avatar
yes... but by "hard run" i only did a couple gear pulls... followed by normal driving... also, i have a power fc i just have to find someone who can tune it... im running the stock ecu for now until then.
good idea... are there any instructions or something so i do it correctly?
Old Feb 16, 2012 | 01:10 AM
Reno_NVFD's Avatar
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/how-install-greddy-oil-catch-can-fd3s-twin-turbo-945797/
antman0408
Oct 5, 2015 04:33 PM
SpaceCadet_Alt3
Oct 1, 2015 11:35 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
