Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
timing problem...
Old Feb 14, 2012 | 08:12 PM
86PICKUPSTICKS103's Avatar
GA timing problem...
i have put a 12a into my 1970 beetle. but when i got the motor the distributor was out. an im just learning on the rotary engine as of 6 months ago. which i love the change btw. but the problem im having is how do i know when i line up the distributor gear mark with the timing mark how do i know its still set when i set into place is there another mark on top?
an do the vacuum advances need to be hooked up while tring to start..
the car will run you just have to spin it for awhile at full advance..
please post a diagram if you have one please.
Old Feb 15, 2012 | 09:47 AM
fidelity101's Avatar
Rallye RX7
You have to line up the pulley to the correct mark with the front cover and then the dizzy there should be 2 marks that need to be lined up when you drop it in. Sounds like your just off a tooth.
Old Feb 15, 2012 | 10:04 AM
what are the two marks
Microtech
30
Apr 23, 2016 06:37 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
incubuseva
14
Sep 3, 2015 12:37 PM
20B Forum
Aug 19, 2015 01:47 PM
