Surging idle
Old Feb 14, 2012 | 08:07 PM
Twin94FD's Avatar
1 up, 5 down
Surging idle
When idling at a stop light the idle will bounce from about 900rpm to 1600rpm about 10 times and then finally settle in at the normal 800rpm. does the throttle body on these cars have an iac? the idle was doing the same thing on my rsx and i just took the iac apart and cleaned it which fixed the problem... the tps voltages are correct... i have a power fc... what could it be?
Old Feb 15, 2012 | 12:49 AM
getgone's Avatar
There is an idle speed control that if it is sticking (or 'dirty' as you say), could cause your problem. It is located on the fire wall side of the UIM just to the east of the throttle body.
Old Feb 15, 2012 | 06:57 AM
Twin94FD's Avatar
1 up, 5 down
ok ill check it out thanks
squirrels
Sep 1, 2024 09:52 AM
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
NLPerformance
Oct 2, 2015 07:11 AM
